Home > Help Needed / General Tech Chat > anyone from croydon on here? or close need help with my turbo engine
blister
Member #: 2590
Croydon
i worked on my mini today and i got the turbo off aswell and the exhaust manifold and i also got the carb off and tomorow the head is coming off as i need to inspect everything due to heavy white smoke under accelration and the engine cuts out when revs build up or changing gear so
whilst its all off what should i check like wear wise and stuff?
Turbo Shed
Member #: 30
Epsom, Surrey
i'm not too far
Did you make sure the fueling was good before you stripped it?
Just a thought from you mentioning it it cutting out.
Mr Joshua
Member #: 1954
Luton Bedfordshire
There is a list of things you should have checked before taking it down.
Own the day
