Home > Help Needed / General Tech Chat > Gaskets
jonb_5
Member #: 3193
Torbay, Devon
Hi
I am rebuilding my engine and it the block was decked 10 thou.
The head is a big valved mg metro 12g940 which has been polished and ported.
The head has had 30 thou skimmed off it and the valves were all re seated.
What head gasket do i need to suit, i.e. make the CR correct.
Also can you get a full engine gasket set i.e, gearbox to block, timing covers, flywheel housing covers, etc. etc.
Jon
retroracer1380
Member #: 1972
Worcester
The only decent one you will probably be able to get hold of at minute is a payen af460 copper gasket
