Home > General Chat > Help Required
jonb_5
Member #: 3193
Torbay, Devon
Hi
I am rebuilding my engine after numerous problems and am not too sure what parts i need as there are so many out there.
Piston Ring kit for 1330, +60 thou pistons
Big end Shells
Main bearing shells
Electric Fan, (to replace the mechanical one)
Thrust washers
Electric Fuel Pump
Fuel Filter
Gaskets for all of engine.
If anyone could post links for the best products, links etc I would be really greatful.
Have i missed anything?
Jon
what pistons mate?
small / big bore....nvm lol big bore
is your crank standard on bigends/mains?
jonb_5
Member #: 3193
Torbay, Devon
Hi
Its a standard crank, the current set up is marked with STD.
They are omega pistons also.
Thanks
Jon
gaskets http://www.minispares.com/Product.aspx?ty=...KET%20SET%208...
+60 omega from minispares http://www.minispares.com/Product.aspx?ty=...A%201275CC%20...
thrusts http://www.minispares.com/Product.aspx?ty=...SET%20CRANKSH...
mains http://www.minispares.com/Product.aspx?ty=...0SIZE%201275C...
bigends http://www.minispares.com/Product.aspx?ty=...D%20SIZE%20EX...
thats assuming your block is A+ also
and is what i just ordered for my rebuild :)
Edited by Brett on 24th Aug, 2009.
id call MED for your rings though, customer service is brilliant and im sure ur pistons are from there (think they are sole supplier for omega)
and id double chech what i put against what u already have check twice buy once*happy*
Mr Joshua
Member #: 1954
Luton Bedfordshire
Dont forget the assembly lube!!!!!!!
Own the day
Also look at your main bearing shells before ordering, the early A plus blocks carried on using the grooved bottom shells with the tag at the side.
t3gav
Member #: 229
Gavin@minispares.com
kent
Remember to use the discount code on the home page!
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Yeah I've done this, saved quite a bit!
On 7th Nov, 2008 Nic said:
naeJ
m
how long the offer going to be on for? I got a big gearbox part order to put through in 2weeks *happy*
where is this discount code?
On the fron page of the minispares website!
Duh! *Jester*
t3gav
Member #: 229
kent
Ends the last day of August :)
And if you've bought online previously, you will have an email telling you....
I have and I haven't.
To be hoped I get vouchers for my b'day on the 30th then....
Edited by apbellamy on 25th Aug, 2009.
