| Home > Help Needed / General Tech Chat > new question! please read and advise. | |||||||
21 Posts Member #: 5544 Member |
25th Aug, 2009 at 05:48:06pm
after searching through the threads and reading a lot of info i'm still none the wiser as to which fuel pump to run. some people are running pumps from random motors from scrap yards, there's a pump in minispares.com they say is specificly for the turbo(part no. TURBO 05) some have fitted the facet red top(but as i can make out thats not the way to go) or a few have gone for running the mpi tank/pump. mine mini is just a standard MGMT, running standard boost, for road use only(no track days or competitions). all advice greatfully received.
25th Aug, 2009 at 05:51:02pm
easiest solution imo is to run one of the £25 electric bosch copy pumps from ebay, then T piece your return line back into the feed to the pump. On 20th Oct, 2015 Tom Fenton said:
25th Aug, 2009 at 06:31:21pm
MPi tank will do the job as will the inline jobby that Nick mentioned.
25th Aug, 2009 at 06:48:08pm
The Bosch copy (various on eBay) is more than adequate, you will need to make sure your return line is large enough though or your regulator may struggle to keep the pressure low enough if it can't spill back enough fuel. Remember the "copy" is designed for fuel injection so has quite a high pressure and flowrate, so that's why a good return is essential. Schrödinger's cat - so which one am I ??? |
25th Aug, 2009 at 08:07:25pm
a fuel inj pump by bosch from the scrappy is what i use , found under numerous cars . think i have a cavalier one in there at the mo ! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
26th Aug, 2009 at 12:56:01pm
You can use the Bosch pump as fitted to W124 chassis mercedez, Escort XR3i XR2i, Cosworths etc etc etc... Orthe pumps fitted to the Rover SD1 Maestso EFi, Montego EFi etc etc.....
Own the day
28th Sep, 2009 at 08:36:11pm
sorry for the delay but ive been on holiday. thanks for the replies, v. helpful. just to be sure- will a spi pump do the job? |
28th Sep, 2009 at 08:38:43pm
Yes, but not for high boost engine. MPi ones are better Edited by apbellamy on 28th Sep, 2009. On 11th Feb, 2015 robert said:
28th Sep, 2009 at 08:47:38pm
The Bosch number for the mero pump is 0 580 464 070. May be useful when searching ebay for one On 12th Nov, 2009 Paul S said:
Gary's description is best |
28th Sep, 2009 at 08:58:23pm
I've got one of these going on the van:
![]() 159 Posts Member #: 1997 Advanced Member Lichfield |
28th Sep, 2009 at 09:54:36pm
im running an spi tank/pump with no problems at all. |
28th Sep, 2009 at 09:58:57pm
all the spi pumps i've tested only put out 1bar, we tried a fair few when we spannered for a mate racing mighty mini's. so anything over about 10psi of boost and you'll need the mpi tank/pump. On 20th Oct, 2015 Tom Fenton said:
28th Sep, 2009 at 10:27:28pm
i must have an mpi tank then, i always thought it was an spi |
29th Sep, 2009 at 09:25:58am
Just to let you now the spi pump is nla from Rover and superceed's to the mpi pump now (WFX100810). |
