Home > Beginners Tech > grinding subframe
turbo22
Member #: 3684
wisborough green west sussex
just got engine fitted and realised the downpipe is gonna be realy close to the subframe,do you have to gring this out or is there a common way of getting over this?
cheers pete
Star Mag
Member #: 375
Leicestershire
I have ground a u shape in mine where the downpipe runs.
turbo22
Member #: 3684
thought so bummer engine out again then.
t3gav
Member #: 229
Gavin@minispares.com
kent
What engine? What downpipe?
Any pics of this? Just so I know where to grind mine before painting it?
Kean
Member #: 341
aka T2clubby
South Staffs
I've never had to grind for a standard down pipe, do you have the adjustable steady on>
I don't even have a steady yet. Suppose I could get an adjustable one and tilt it forward a bit.
Star Mag
Member #: 375
Leicestershire
I mean the subframe, gives it more clearance. But thinking about it this was when I used to use the standard top mount rather than the adjustable one I have now!
What turbo and manifold have you got?
With a mirage of T3 on a metty manifold this shouldn't be necessary.
In fact there is enough room in most cases. However, I ground the flange a bit to aid fitting of mine, but it's well clear.
turbo22
Member #: 3684
To be fair i have only just got the engine in, have not got to top mounts in yet and i have got an adjustible one so by the sounds of it should be ok ill update later.
you should not need to grind the subframe away at all
i know a lot of people grind the lip a bit but its not much. i didnt have to
I haven't ground mine. Get the top steadys on and see what its like then.
Oh and also make sure that the exhaust is hanging 'right'. The downpipe should be at a slightly angle. If the exhaust is sitting too far back, it could cause the downpipe to foul the subby.
turbo22
Member #: 3684
Right made some major progress today, as said there is no need to grind subby if you have an adjustible engine steady.I have wound the steady out enough so the engine is as straight as possible to the eye which has given me about 5mm gap between the subby and the downpipe, i could go more but i dont think its needed.
