| Home > General Chat > Welding T45 | |||||||
27th Aug, 2009 at 01:27:13pm
Right you knowledgeable bunch, i know that its recommended that you use ER100S.G wire to weld T45.
27th Aug, 2009 at 01:31:02pm
Its still steel, normal wire is fine
I seriously doubt it! |
27th Aug, 2009 at 01:44:16pm
That's what i was thinking. But then i was also thinking its apparently higher in chrome and magnesium so might need to have the better grade wire.
27th Aug, 2009 at 01:47:45pm
Try the MIG on some normal steel.
27th Aug, 2009 at 02:20:40pm
Fresh wire Paul. Thinking about it, the tubes are a little greasy to the touch. I'll wipe down (no brake cleaner) the next area i weld and see. |
27th Aug, 2009 at 06:00:04pm
Your wire speed too slow? On 19th Jan, 2010 wil_h said:
27th Aug, 2009 at 06:35:12pm
Hmm, it could be Jason. I haven't actually had a play with the feed. I'll crank it up abit this weekend if i get out there and see.
204 Posts Member #: 5022 Senior Member Oxford, Kings Lynn, Pod, Pub. |
27th Aug, 2009 at 07:07:08pm
Degrease the tubes, and it may even be worth given them a light emery with some paper by hand this will remove any scaling etc, this made the ease/cleaniness of welding my chromoly better and more consistant but i was using Tig and it is my preffered weapon of choice.
Got A GTM With A Honda In the Back, and huge Nitrous bottle where the passenger seat should be when racing!
On 19th Oct, 2009 Nic said:
Ill donate to the cause if you can make it do wheelies!! |
