| Home > General Chat > OT - Lawnmower Smoking | |||||||
29th Aug, 2009 at 02:03:37pm
My trusty 150cc, 4 stroke Briggs & Stratton lawn mower has started spewing white smoke out of the exhaust. Before I start stripping it any idea as to what the culprit might be? Isambard Kingdom Brunel said:
29th Aug, 2009 at 02:20:27pm
its fooked! not worth repairing at a guess! |
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
29th Aug, 2009 at 02:31:05pm
white smoke? interesting! Have you tried changing the oil and filters?
29th Aug, 2009 at 02:31:09pm
Oil seals in the turbo?? On 11th Feb, 2015 robert said:
29th Aug, 2009 at 02:49:36pm
As it's (presumably) an air cooled engine, I would say contaminated fuel (ie, water got into tank or fuel can or it's been contaminated by diesel).
Edited by Rod S on 29th Aug, 2009. Schrödinger's cat - so which one am I ??? |
29th Aug, 2009 at 03:16:01pm
my guess is bore/rings excessively as it chucks out white smoke.
29th Aug, 2009 at 03:19:21pm
the briggs engines suffer from the seal perishing between the fuel tank and the motor might be worth a look Crystal Sound Audio said:
29th Aug, 2009 at 03:49:15pm
Benson & Hedges ???? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
29th Aug, 2009 at 03:52:41pm
Tried Nicotinell, yet ? |
84 Posts Member #: 2404 Advanced Member Braintree, Essex |
29th Aug, 2009 at 08:47:45pm
On 29th Aug, 2009 Paul S said:
Benson & Hedges ???? Grass? Geoff |
29th Aug, 2009 at 09:37:05pm
Don't forget to sharpen the blades so you get a Silk Cut |
29th Aug, 2009 at 11:03:45pm
what advance and boost are you running,
30th Aug, 2009 at 12:10:59am
bore flex? "Turbo's make torque, and torque makes fun"
31st Aug, 2009 at 02:07:50am
31st Aug, 2009 at 10:04:28am
Have you recently been around mini13? If yes you can bet on it being the worst possible scenario! |
31st Aug, 2009 at 02:14:31pm
On a more serious note. I have one that spewed out white smoke after mowing at a silly angle. I guess the oil had passed the rings. After a while it cleared. http://www.twin-turbo.co.uk
