| Home > Help Needed / General Tech Chat > Clutch arm clevis pin | |||||||
617 Posts Member #: 6558 Post Whore Pueblo, Colorado, USA |
29th Aug, 2009 at 04:49:38pm
I think across the pond you guys might have a different term for it, but the clevis pin that holds the clutch arm(pre-verto) to the flywheelhousing, what is the easiest way to get that out? If it weren't thirty years old(yes it's the original clutch) I imagine it would come right out, but it is the original, and it is securely held in place, but not by a split/cotter pin, by rust. Has anyone else had this problem, and if so, what did they do to fix it?
29th Aug, 2009 at 05:00:27pm
just drift it out after soaking with some penetrating fluid. it will come out.
29th Aug, 2009 at 05:02:57pm
Clevis pin is UK too...... :)
Edited by Rod S on 29th Aug, 2009. Schrödinger's cat - so which one am I ??? |
29th Aug, 2009 at 05:03:26pm
It's still in situ. The cars my daily driver, and I figured while I was getting the head fixed I would replace the clutch mechanicals.
29th Aug, 2009 at 05:04:52pm
It is rusted to the arm. And I buggered up a finger and a forearm on the damned thing. :) Minis, got to love 'em.
29th Aug, 2009 at 05:10:04pm
problem is it always gets put in the easiest way, which makes it the hardest to get out!
29th Aug, 2009 at 05:10:25pm
OK, is the split pin end at the back (downwards) or front (upwards) ???
29th Aug, 2009 at 05:17:58pm
I'm just replacing the stuff outside the clutch, the arm, clevis pins, push rod and slave cylinder. It is fit so that the split pin is inserted nearest the bulkhead. I think I may end up grinding it down and doing it that way. I was just hoping someone had a better idea, because that's going to take a while, my compressor took a dump.
1st Sep, 2009 at 05:33:54pm
in the uk, if you buy new clevis pin, slave and arm they tend to wear out in a short time as there all patern parts and made of crap |
