Home > Help Needed / General Tech Chat > why wont it turn over?
Mini_Andy
Member #: 432
I've been an idiot, i let the engine stand for about 18 months - 2 years......
now i have connected all up again, put a fresh battery in and turned the key.
all i get is a clunk??? at first a thought it was the starter (still might be) however it all looks ok. i'm confident i have the wiring sorted. so i thought the engine might be siezed (sp??) i took the plugs out (no idea if that helps!) and turned it over by hand via the driveshaft nut and a lot of effort! (in second gear)
It sort of turned over, but then when i tried it on the ignition i still got the same clunk, what the fook have i done wrong? i can take a picture if it will help.
Sounds alot like the solenoid on the starter is sticking.
Give it a tap with a hitting stick and try again.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Could be solenoid.
Pull the plugs out, put a little oil/diesel down the bore. Just in case rings are sticking to the bores.
Turn over by hand. If all is okay, put plugs back in. Thats what I normally do if an engine has been layed around for a long time.
Edited by Jason G on 30th Aug, 2009.
On 19th Jan, 2010 wil_h said:
adam1330
Member #: 238
essex
is the engine earthed correctly?
philc
Member #: 1346
bromsgrove
put live direct to starter motor this will tell you whether starter or solinoid or both
Mini_Andy
Member #: 432
earth is fine, i'll try 'tapping it' tomorrow.
How much oil are we talking? just a drop? and then do you leave it for a while? or turn it over by hand again?
should i try turning the starter with it out the car connected to a battery?
thanks all :)
Pull the plugs and stick a scroddy accross the terminals of the solenoid. If it turns then your solenoids dead!
Jason G
Member #: 1459
En-suite user
Braintree, Essex
not alot, say a teaspoon. Just in case rings are rusted to the bores. Then turn over by hand gently. If everything feels ok, turn over using the starter untill you have an oil pressure. Then stick plugs back in.
thanks all :)
ill give you a hand one evening if you want Andy
nutter driver
Member #: 47
Not very sunny swanage
not trying to be a prick, but the battery is properly charged isnt it? ive had this before, and it turned out the freshly charged batt i was using was in fact, nfg......
Mini_Andy
Member #: 432
yea the batt is good and strong.
Thanks for the offer wolfie, but i won't be able too look at it for a few weeks now, as i have dedicated all my free to charity! i am training to be a community first responder with St Johns :)
