| Home > Help Needed / General Tech Chat > TURBO CARB (WERE SHOULD THE JET BE SET) | |||||||
196 Posts Member #: 2301 Advanced Member Blackpool , Lancashire |
31st Aug, 2009 at 08:03:18pm
CAN ANYONE TELL ME WERE THE JET SHOULD BE SET STANDARD ? http://s256.photobucket.com/albums/hh167/boz-reb-2303/
31st Aug, 2009 at 08:20:38pm
It needs to be whereever it needs to be to idle right, and maintain decent emissions.
31st Aug, 2009 at 08:28:52pm
tHATS THE PROBLEM IVE GOT IT WONT START. SHULD I JUST GET IT LEVEL AND GO FROM THERE. http://s256.photobucket.com/albums/hh167/boz-reb-2303/
31st Aug, 2009 at 08:33:35pm
You need to acertain wether that is preventing ti to start. Are you sure the ignition system is operating correctly?
31st Aug, 2009 at 08:37:03pm
I THINK I READ SOMEWHERE THAT A GOOD STARTING POINT IS 0.75MM DOWN FROMT HE BRIDGE, THATS FOR NA APPLICATIONS, BUT I IMAGINE STARTING/OFF BOOST RUNNING IS THE SAME
1st Sep, 2009 at 10:57:56pm
On 31st Aug, 2009 boz-reb-2303 said:
tHATS THE PROBLEM IVE GOT IT WONT START. SHULD I JUST GET IT LEVEL AND GO FROM THERE. There are many many reasons why an engine wont start. The jet height is one possibility. Clearly if it wont start with the jet "high", and the plugs remkain dry. It would be worth lowering the jet and adding fuel. But that would take less time to try, than its taken to post here on the internet about it. So what was the outcome ? 9.85 @ 145mph
3rd Sep, 2009 at 10:21:00am
On 31st Aug, 2009 joeybaby83 said:
I THINK I READ SOMEWHERE THAT A GOOD STARTING POINT IS 0.75MM DOWN FROMT HE BRIDGE, THATS FOR NA APPLICATIONS, BUT I IMAGINE STARTING/OFF BOOST RUNNING IS THE SAME GOOD LUCK MATE The base line starting point is level with the bridge. Own the day
4th Sep, 2009 at 01:39:00pm
not according to corky bell "Turbo's make torque, and torque makes fun"
5th Sep, 2009 at 06:36:34pm
ok Ive got it running thanks http://s256.photobucket.com/albums/hh167/boz-reb-2303/
5th Sep, 2009 at 06:39:24pm
I just set it leval and then turned it anti clock wise 2 full turns. Bingo http://s256.photobucket.com/albums/hh167/boz-reb-2303/
5th Sep, 2009 at 06:39:27pm
