Home > Help Needed / General Tech Chat > Verto clutch torque settings
madcatminis
Member #: 5327
Dudley, West mids
Hiya all. I need to know the torque settings for the 6 bolts that hold the large thingy majig (don't know what it's called) *oh well* onto the verto pressure plate. It's the bit that has a cut out in it for the key plate and flywheel nut. Are these bolts thread locked in.
Also what are the bolts that bolt the pressure plate to the flywheel on a verto set up, and what grade material and torque settings are these. Would mini spares have these??? oh and another question. What is the retaining clip that holds the clutch release bearing onto the plunger??? Can I get these from mini spares?
Cheers chaps *happy*
44lbft for the center 18lbft for the outer. no less than grade 8 bolts I would suggest
The retaining clip thingy, i have used an o ring in the past
For all the other bits why not look on Minispares
Simples
Edited by Sprocket on 31st Aug, 2009.
Minispares don't sell the 6 retaining bolts unless you buy them in a kit.
