| Home > Help Needed / General Tech Chat > 0-5v Sensor Outputs | |||||||
857 Posts Member #: 1778 Post Whore Northants |
1st Sep, 2009 at 04:37:19pm
This is one for the electrical minded folk
1st Sep, 2009 at 05:03:14pm
been along time since i did my alevels but couldnt a zero gain amplifier be used?
Edited by Brett on 1st Sep, 2009. Yes i moved to the darkside |
1st Sep, 2009 at 05:08:15pm
had a quick look, google voltage follower bit of info here too
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
1st Sep, 2009 at 05:20:26pm
You know I was just thinking about this the other day as I'm considering taking the output from the temp sender and sharing it with both the gauge and Megajolt to adjust the timing.
1st Sep, 2009 at 06:11:35pm
The following link shows how to share a temperature sensor on Megasquirt: http://www.megamanual.com/v22manual/sharesen.htm.
1st Sep, 2009 at 07:58:48pm
Would a good old 741 work? Isambard Kingdom Brunel said:
1st Sep, 2009 at 09:25:03pm
i've shared sensors between my ecu and data logger without any problems On 15th May, 2009 TurboDave said:
