Home > Wanted > clutch cover
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
Does anyone have a clutch cover that they can sell to me? For pre verto.
-James
the covers are all the same
miniswordsman
Member #: 6558
oh.
the plunger lever arm and release bearing are different on the A+ and Pre A+ if you have a cover this is all you need to change
if you dont have anything then anycover will do as long as you fit the pre A+ plunger, lever arm and release bearing
Edited by wolfie on 1st Sep, 2009.
miniswordsman
Member #: 6558
Then I just need one. I only had one, and it broke.
-James
stefaz
Member #: 1656
stoke-on-trent
which bit broke exactly?
Anton
Member #: 764
Staffordshire
I have a spare one knocking around the garage.
i'm guessing the clevis bit since there was a post on about getting it out...
doh!
Turbodave might be able to help, or turbo tel being the right side of the pond
miniswordsman
Member #: 6558
I'll have to check back with some later, there's a moderator on minifinity that has one too and he's offered it to me. As far as being on the correct side of the pond, it's not a problem, I have a friend over there that can ship stuff dirt cheap to me. He's in the U.S. airforce, so he can ship from an APO there to and APO here, so it's really cheap.
