| Home > Help Needed / General Tech Chat > Turbo carb help | |||||||
![]() 5 Posts Member #: 7001 Junior Member New Zealand |
3rd Sep, 2009 at 07:49:12am
Is there anyway i can modify my standard carb to suit a turbo conversion? or is there any other alternative carb i can use? Because its nearly imposible to find a hif44 carb here in nz >.< |
3rd Sep, 2009 at 07:58:37am
Not sure if you can rebuild an n/a one as turbo, but Turbo Phil is listing a genuine Turbo carb on his website. He also stocks genuine rebuild kits.
3rd Sep, 2009 at 08:07:34am
Hmm, il have a look. thanks |
3rd Sep, 2009 at 08:33:10am
i converted mine, basically reverse the seals on the n/a carb and either use the 'T' mod/ bypass or drill an air passage i had to change the throttle cable thing too... maybe something else :)
Yes i moved to the darkside |
3rd Sep, 2009 at 10:02:01am
INIW - when you say "standard" (the one you have now) is it a standard HIF or an HS ?
Edited by Rod S on 3rd Sep, 2009. Schrödinger's cat - so which one am I ??? |
![]() 140 Posts Member #: 1367 Advanced Member Cape Town, South Africa |
3rd Sep, 2009 at 04:16:37pm
I managed to pick up a carb, manifold and plenum on fleabay, was 80quid, but with shipping came to a total of 155quid (excluding import tax), will have to think twice about bringing in stuff. Glad I got the carb, noted quite a few differences between the NA HIF44 and the turbo variant.
3rd Sep, 2009 at 04:52:46pm
have a look over these 2 threads
6th Sep, 2009 at 04:26:31am
I have a standard HS. Possible to convert? |
6th Sep, 2009 at 07:48:08am
On 6th Sep, 2009 INIW said:
I have a standard HS. Possible to convert? That is what I suspected from your first post :) It has been mentioned on here before but I can't find the thread. From memory the issues are how to pressurise the float chamber (as it's external rather than integral), fitting the plenum so the restrictor ring still works, and sealing the throttle spindle and possibly the jet itself. Hopefully someone more knowlegable about carbs will correct me. Schrödinger's cat - so which one am I ??? |
6th Sep, 2009 at 09:36:38am
I would have thought that the seal between the float bowl and the tube to the jet could be tricky to seal if it was pressurised. Isambard Kingdom Brunel said:
