| Home > Help Needed / General Tech Chat > How do I know if a head has been converted to unleaded? | |||||||
56 Posts Member #: 377 Advanced Member Maidstone, Kent |
5th Dec, 2004 at 04:04:17pm
Hi guys Rebuilding a 1992 mini...will be finished in 2019 |
5th Dec, 2004 at 11:45:41pm
Standard leaded heads have the valve seats cut into the cast iron. Unleaded heads have inserts on the exhaust ports that you can usally see when the valves are out.
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
6th Dec, 2004 at 12:07:47am
Pull a valve out and you can just tell. Bugger off, I'm getting there. |
7th Dec, 2004 at 07:55:58am
Yeah as sumpnut said, the exhaust valves on an unleaded head have a pressed in insert. its made of better quality/harder material than the casting so can cope with running unleaded fuel. |
7th Dec, 2004 at 07:56:25am
ps: you may have to clean up well round that area to see it, sometimes tricky |
