| Home > Help Needed / General Tech Chat > Help with removing cones | |||||||
4th Sep, 2009 at 07:40:42pm
i tried to fit my coilovers last night to the front of the mini, only problem was about half way through tightening the compressor there was a loud bang and it shot up as its tension was realeased due to the puller coming loose.
4th Sep, 2009 at 07:46:33pm
pull the the arm pivot pin out, its come out then. On 28th Aug, 2011 Kean said:
4th Sep, 2009 at 07:50:46pm
First is it the right thread you've been using on the puller (early are imperial, later are metric).
Edited by Rod S on 4th Sep, 2009. Schrödinger's cat - so which one am I ??? |
5th Sep, 2009 at 09:02:35am
or... hack saw through the trumpet + hit with big hammer.... :) Yes i moved to the darkside |
5th Sep, 2009 at 09:15:39am
On 5th Sep, 2009 Brett said:
or... hack saw through the trumpet + hit with big hammer.... :) On 11th Feb, 2015 robert said:
5th Sep, 2009 at 09:19:44am
On 5th Sep, 2009 apbellamy said:
I would have thought the preasure applied by the cone will close the gap as you cut. I would just smash the trumpets with a BFH. tbh my cones were that flat after removing the lower bump stop i had just enough room to pull it all out.... putting the fooking huge red dots in there with adjustable cones was difficult though
5th Sep, 2009 at 10:57:40am
i like the BFH idea just because of what it means lol. good point about the threads for the puller i never thought of that, maybe i can try the other to reduce the pressure and remove the top arm :), cheers peoples
5th Sep, 2009 at 11:08:09am
if the threads are suspect when its compressed KEEP YOUR FINGERS OUT OF THERE!!
