Home > General Chat > possible crank sensor fail?
MONSTER HEDGEHOG
Member #: 4340
sideways, Birmingham
ok guys, this is a good one :)
i just got my smart car back in one piece after a full engine rebuild (burnt out valve, common problem) anyway, it starts fine and drives fine, after about 15mins driving or idling it stalles and wont restart for about 30 mins, it turns over happily on the starter with no spark or anything, once its cooled down a bit it fires happily into life and drives normally again, ive hooked it up to a diagonal stick and it brings up no errors, and no sensor readings at all when its cranking over and not starting,
ive asked on smart car forums but reconed its worth asking here as i recon turbo mini people are more hands on than a large number of smart car owners *happy*
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol
carl
FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR"
Nick
Member #: 154
Midlands
coil pack getting hot and conking out?
take it to where the re-build was done and blame them :)
MONSTER HEDGEHOG
Member #: 4340
there are 3 coil packs one for each cylinder, its a very clever engine. *happy*
it has 6 valves, 6 spark plugs, 3 200cc cylinders with oil cooled pistons, a t12 turbo with air intake and boost out ports the size of penny pieces, a chain driven cam, and no cat on a 99/2000 car!!!!
carl
why 6 plugs? arnt 3 good enough?
MONSTER HEDGEHOG
Member #: 4340
... errr... that would be me *blush*
Edited by MONSTER HEDGEHOG on 5th Sep, 2009.
carl
MONSTER HEDGEHOG
Member #: 4340
i think 2per cylinder work better for a cleaner burn
carl
MONSTER HEDGEHOG
Member #: 4340
sorted, def the crank sensor
carl
