| Home > Technical Chat > Interesting Info on Piper Cams | |||||||
6th Sep, 2009 at 04:28:34am
http://www.demon-tweeks.co.uk/resources/pdfs/PIP_CAM.pdf
6th Sep, 2009 at 09:13:25am
detting at 50@??? you should try the recommended timing at 24-60... |
6th Sep, 2009 at 09:13:56am
i think your getting a little confused here between cam timing figures and ignition figures,
6th Sep, 2009 at 10:05:16am
On 6th Sep, 2009 Johnny said:
Getting fed up with never finding a straight answer to why things like these happen :( With respect, the problem is maybe your understanding of engine basics. Firstly a BP255 is not a PH2
Secondly, as Carl said, you are confusing ignition and cam timing. My advise would be to get hold of a good book on engine basics. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Sep, 2009 at 12:47:36pm
yeah true, but im on about ignition timing?
6th Sep, 2009 at 12:53:48pm
or better never touch again an engine ! oh its not me touching it, im just relaying info from the RR guy |
6th Sep, 2009 at 12:55:57pm
so what does the 24-60 mean? Inlet valve, 24 degrees before top dead centre to start openning. 60 degrees after bottom dead centre to be closed. 24 plus 180 (difference between top and bottom dead centre) plus 60 = 264 (in the duration column of the table) mirror image for the exhaust valve. Nothing to do with ignition timing :) EDIT - and I may as well add.... 108 degrees in the "full lift" column (ie, what it should be timed in at) is, Duration 264 degress divided in half (assuming it's a symettrical cam) is 132 degrees for maximum lift. Start is 24 degrees before top dead centre so full lift is 132 minus 24 which equals 108 degrees after top dead centre. Again, the exhaust is a mirror image if you do the sums. Edited by Rod S on 6th Sep, 2009. Schrödinger's cat - so which one am I ??? |
6th Sep, 2009 at 12:56:59pm
6th Sep, 2009 at 04:50:31pm
Thank you Rod, and yes mini13 ive been told lots about this topic, and ive stopped using the mini untill its sorted, im loosing my faith in it :(
6th Sep, 2009 at 05:47:35pm
All I would say is that if it's been on a Rolling Road with 44 degrees ignition advance (under full load) and is still in one piece,
6th Sep, 2009 at 06:54:38pm
Maybe the damage is already done which is why it doesnt run right On 26th Oct, 2004 TurboDave16v said:
7th Sep, 2009 at 05:18:30pm
the cam timing is set at 108 probably within a half degree of tolerance.
7th Sep, 2009 at 06:03:31pm
If your cam timing really is 108 degrees (ie, about right for whatever the cam actually is) but your ignition advance is actually going to 44 degrees under boost AND you say it was going to 50 degrees advance before the RR and you could hear detonation at santapod with it at 50 degrees (and presumably kept your foot down anyway) I tend to agree with Sprocket.
10th Sep, 2009 at 07:10:23pm
Cheers Rod and it detted in 4th so i let off to half throttle for the last second or two, really diddnt like it at all, tried getting the timing down at santa pod but still no luck. the mini is in bits at the moment, a (recon) turbo is on its way as the old one was completely fucked, dare i say i won a dizzy off ebay (sorry to those who were bidding) supposedly in working condition, so i get the turbo tomorrow and the dizzy whenever lol hopefully saturday..
