| Home > Help Needed / General Tech Chat > Hardy spicers and cross pin diff | |||||||
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
6th Sep, 2009 at 06:10:47pm
I have acquired a set of hardy spicers that i am thinking about fitting.
6th Sep, 2009 at 06:18:04pm
You can get some adaptors to connect to the pot joint ouput shafts.
6th Sep, 2009 at 06:23:00pm
Swiftune sell them, but you can get them cheaper elsewhere I believe.
6th Sep, 2009 at 06:28:07pm
ouch they are expensive!! |
6th Sep, 2009 at 06:36:35pm
I reckon Carl could make you a pair, no idea if they'd come in cheaper mind. Isambard Kingdom Brunel said:
6th Sep, 2009 at 06:48:37pm
On 6th Sep, 2009 Paul S said:
You can get some adaptors to connect to the pot joint ouput shafts. I'll see if I can find a link. I could never understand the theory behind these as its the pot joint output shafts that are the weak link, which is why people use the hardy spicers. Yes you will have to fit the HS output flanges in the diff, which will need dismantling to do so. I bought a pair of HS output flanges to find that some one had turned them down to fit a standard diff side cover. Seemed to work a treat in that respect. Edited by Sprocket on 6th Sep, 2009. On 26th Oct, 2004 TurboDave16v said:
6th Sep, 2009 at 07:02:08pm
having never had a cross pin before will i will be bale to take ti apart and fit the hardy spicer outputs on to it? Is that right or am i getting confused with what i need to do?
6th Sep, 2009 at 07:08:17pm
The output shafts should fit no problem.
6th Sep, 2009 at 07:10:15pm
ahh right so actually it will be really easy to swap out with the current cage.
6th Sep, 2009 at 07:20:18pm
you will also need the four collets, two rubber seals, and the two large (special) bolts.
7th Sep, 2009 at 01:48:40pm
where do the two large (special) bolts go? |
7th Sep, 2009 at 05:29:43pm
http://www.somerford-mini.co.uk/pdfs/Catal...ifferential.pdf
7th Sep, 2009 at 05:36:23pm
This does seem a lot of money for little if no advantage. I think I'm one of very few on this forum who've broken a pot joint. They are very reliable. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
7th Sep, 2009 at 05:36:26pm
Infact, perhaps Somerfords can supply these bolt. I'll give them a call tomorrow and find out. On 26th Oct, 2004 TurboDave16v said:
7th Sep, 2009 at 08:32:02pm
On 7th Sep, 2009 wil_h said:
This does seem a lot of money for little if no advantage. I think I'm one of very few on this forum who've broken a pot joint. They are very reliable. I swapped the whole setup for a 2.95:1 FD setup!! So got it for a bargain i think. |
