| Home > Help Needed / General Tech Chat > Removing idler bearing retaining ring | |||||||
![]() 36 Posts Member #: 2745 Member Milton Keynes |
6th Sep, 2009 at 08:56:21pm
This is probably a ridiculous question to ask as the Haynes says "remove the retaining ring" (well it actually says 'reatining ring'...) like it's so straight forward and doesn't need explanation, but...
7th Sep, 2009 at 08:07:26am
well there isnt one for the idler bearing only for the nose bearing ( the one at the bottom) use a small screw driver to get the ring out, then clean properly, then bake in the oven placing upside down so the fall out, proberly take 20 mins at 180 deg c , only do when wife or mum is out because it will stink fairly. always looking for them bigger bunches of bannanas |
7th Sep, 2009 at 09:31:29am
that's the one! (sorry for the confusion) - i'll attack it with a small screwdriver later and see what happens...
282 Posts Member #: 1404 Senior Member The Netherlands |
9th Sep, 2009 at 03:09:05pm
On 7th Sep, 2009 turbo hogster said:
then clean properly, then bake in the oven placing upside down so the fall out, proberly take 20 mins at 180 deg c , only do when wife or mum is out because it will stink fairly. This trick realy worked for me, exeped i didn't clean the casing so i got a little bit of smoke , my wife didn't smell one thing..... But a light tap with a rubber hamer and it fell right out
there is nothing wrong with a A-series that a turbo can't fix.
9th Sep, 2009 at 03:19:46pm
If you put the whole casing in the dishwasher first (obviously while wife/GF/other is out of the house too) you won't get so much of the smell when it's in the oven.......
9th Sep, 2009 at 03:23:19pm
No point just putting the idler case in though, you may as well get the wok and filter housing etc cleaned up at the same time Edited by apbellamy on 9th Sep, 2009. On 11th Feb, 2015 robert said:
10th Sep, 2009 at 11:24:52pm
It's gone in alongside the metals racks in the Oven Pride cleaning kit bag... Leave to soak overnight - "it's so easy, even a man can do it"... |
11th Sep, 2009 at 07:39:41am
Hmmm....
