| Home > General Chat > Oil pumps | |||||||
9th Sep, 2009 at 04:40:45pm
is the best pump to get still from avonbar or have others caught up yet?
Yes i moved to the darkside |
9th Sep, 2009 at 05:39:49pm
minispares do the same powerflow turbo pump now aparently. On 28th Aug, 2011 Kean said:
9th Sep, 2009 at 05:54:06pm
you don't have to spend big money on a avonbar oil pump, if you were to get a standard oil pump for a 1300 n/a that will be fine. Best 1/4 mile 13.2 seconds @116 mph
9th Sep, 2009 at 06:15:24pm
9th Sep, 2009 at 06:55:03pm
have you tried them with oil jets then mate??? Best 1/4 mile 13.2 seconds @116 mph
9th Sep, 2009 at 07:10:25pm
yep, seems to struggle to keep good pressure a little on a hot engine,
9th Sep, 2009 at 07:38:40pm
On 9th Sep, 2009 Miniwilliams said:
you don't have to spend big money on a avonbar oil pump, if you were to get a standard oil pump for a 1300 n/a that will be fine. that is quite reassuring actually coming from yourself but as mini13 said i will be running with oil jets although possibly the ones with the ball bearing to shut them off at low oil pressures, i may be feeding oil to the thrusts as well and obviously the T2 do you think the na pump will be good for all that? Yes i moved to the darkside |
549 Posts Member #: 5327 Post Whore Dudley, West mids |
9th Sep, 2009 at 07:45:40pm
Yeah minispares have started selling the powerflow pumps. These are excellent!!! I've used one of the turbo powerflow pumps before and it was top. |
9th Sep, 2009 at 07:45:47pm
On 9th Sep, 2009 mini13 said:
minispares do the same powerflow turbo pump now aparently. As stated, the "turbo" one I got from MiniSpares a year ago was the steel backed Powerflow one, and not much more expensive than the standard one. So unless they have changed their supplier since then.... Probably overkill in my case (no oil jets) as the turbo doesn't add that much to the flow requirements but better too much than too little..... Schrödinger's cat - so which one am I ??? |
9th Sep, 2009 at 08:04:02pm
also on my current engine i plugged the oil drain from the presure releif ( apart from a small 2mm drain hole) and redrilled it out he side of the block so all the exess oil gets dumped onto the transfer gears. On 28th Aug, 2011 Kean said:
9th Sep, 2009 at 10:37:45pm
Great stuff mini13 thats what i like to hear, someone that is speaking from there own testing and not just thinking what it should or shouldn't do Nice one Best 1/4 mile 13.2 seconds @116 mph
10th Sep, 2009 at 02:08:43am
also on my current engine i plugged the oil drain from the presure releif ( apart from a small 2mm drain hole) and redrilled it out he side of the block so all the exess oil gets dumped onto the transfer gears. i like that idea :) Yes i moved to the darkside |
10th Sep, 2009 at 07:26:25pm
my thoughts and experiences are with mats and brett, not needed
10th Sep, 2009 at 08:53:04pm
Interesting comments...
10th Sep, 2009 at 09:12:41pm
nope,
10th Sep, 2009 at 10:44:57pm
Myself and Paul converted a Powerflow pump for use on my A+ 1098. Initial readings at idle were 70-80 PSI with zetec oil jets. Do people see similar readings with these pumps in big bores too? Is there much difference in oil capacity between big and small bore On 12th Nov, 2009 Paul S said:
Gary's description is best |
10th Sep, 2009 at 11:42:07pm
On 10th Sep, 2009 mini13 said:
nope, I stole the idea off somone on the efi minis forum. 8-)
11th Sep, 2009 at 09:47:15am
I use a Turbo high capacity pump which gives around 70/80 psi cold (probably overcoming the relief valve,s flow capacity) dropping to 50/60 psi at cruise and under 20 psi at idle, when hot.I prefer the idea of excess flow capacity,but agree with the common view that too high a pressure achieves little other than heating up the oil and consuming some power.The motor is and inline 1275. |
20th Sep, 2009 at 07:08:12pm
top idea about dumping the excess oil onto the drops, might rob the idea myself "Turbo's make torque, and torque makes fun"
339 Posts Member #: 399 Senior Member Austria |
18th Jan, 2010 at 09:17:53am
Turboharry modified an oil pump:
