| Home > Beginners Tech > Benefits of GT series turbos? | |||||||
617 Posts Member #: 6558 Post Whore Pueblo, Colorado, USA |
10th Sep, 2009 at 04:50:02pm
Okay, I got to reading up on some of the GT turbos. What's the real benefit? As far as I can tell the only real difference is the ball bearing instead of regular bearings. Did I miss read somewhere or is this the case? In a different thread it was recommended that I go with a GT15 turbo for my 850cc project. Now, I assume this is because of size of the motor, which is fine. But I was wondering, for the larger turbos, wouldn't a T3(yes I know, outdated...) from the likes of Turbonetics be just as good? They are now using ball bearings in almost all of their turbos.
10th Sep, 2009 at 05:22:09pm
Ball bearing cores are not really of concern to us, as they only start from the GT25 series upwards.
10th Sep, 2009 at 05:44:46pm
yep, they generally flow more for their wheel sizes, and as a result have less inertia, also they can be designed hold their efficiency at higher pressures. On 28th Aug, 2011 Kean said:
10th Sep, 2009 at 06:02:50pm
ah. okay. That clears some up. Now, lets say a GT15 turbo doesn't hold enough power for the 850, theoretically, would a GT25 be best then?
10th Sep, 2009 at 06:12:55pm
The GT1548 will flow enough air for 120hp.
10th Sep, 2009 at 06:13:34pm
a gt15 will,
10th Sep, 2009 at 06:17:22pm
have a play with this calculator,
10th Sep, 2009 at 06:18:53pm
Ah. So gt17 would probably be the ticket then once I have the motor built. Now, here's the thought. I'm building the motor to the nines, everything built for turbo(crank, rods and pistons included). What would be the estimated power output would someone say of an extremely well sorted 850cc turbo with a GT17 or a GT20? I'm looking for no less than 125bhp, but I would want more.
10th Sep, 2009 at 06:23:12pm
tbh i think even the gt15 might be a bit big,
10th Sep, 2009 at 06:27:06pm
On 10th Sep, 2009 miniswordsman said:
Ah. So gt17 would probably be the ticket then once I have the motor built. Now, here's the thought. I'm building the motor to the nines, everything built for turbo(crank, rods and pistons included). What would be the estimated power output would someone say of an extremely well sorted 850cc turbo with a GT17 or a GT20? I'm looking for no less than 125bhp, but I would want more. -James If you want more than 125bhp, then do not start with an 850. They are not known for their strength. However, a fairly standard 998 A+ will be OK up to around 150 hp or more. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
10th Sep, 2009 at 06:31:02pm
Well the GT17 works very well on our racer and is good for 150+ bananas on a 998. A mate has an 875 imp engine with a GT17 on and that works well too, but it revs much more than a mini engine.
http://www.twin-turbo.co.uk
10th Sep, 2009 at 06:41:39pm
That's about what I'm figuring. I know a 850 is really not the place to start, but it's unique I think. How many people on this forum, or anywhere really, have a 850cc A-series turbo mini? When I have Crower do up my crank and rods and such I'm going to have them do the crank for high rev. I'm looking to get 8500 to 9500 rpms out of the motor, and still have it be as reliable a motor as one like this could be... |
10th Sep, 2009 at 07:08:48pm
I thought long and hard about using an 850 for my turbo/mpg project. In the end, I decided to take the easy route and use the 998.
10th Sep, 2009 at 08:41:51pm
I plan on having crower do the whole bit up for me. Custom crank, titanium con rods and custom pistons dished for turbo use. When they have it in shop I'll have them line bore and install the cam bearings as well, because as you said they are not fitted. |
11th Sep, 2009 at 02:34:16am
Titanium con rods?
11th Sep, 2009 at 03:25:29am
I'm just willing to pay a lot to get what I want. They're $560 a piece, so roughly 335 pounds a piece. But Crower guarantees against their failure. The whole motor is probably going to cost $6,000(3500 pounds). Granted this is without the gearbox, but it will create a much more reliable motor, and a much more powerful one because the parts will be lighter and better balanced. Like they say, you get what you pay for. However, MED's forced induction motor is 5700 pounds, or $9,500 U.S. currency, which is what I'm going to spend roughly for the whole motor and tranny as well, but have a motor that is tricked to the nines.
11th Sep, 2009 at 03:26:59am
Not to mention, it'll be one of the few 850's that can keep up with quite a few 1275cc motors... |
11th Sep, 2009 at 04:30:26am
I must say that while you will have a unique engine, you'd get at least 50% more power starting from a 1275 and would not spend more than what you will on the 850. And it would still be unique with those parts.
11th Sep, 2009 at 07:45:12am
I don't think this project is about the ultimate forced induction motor, it's about the ultimate 850 motor.
11th Sep, 2009 at 08:53:22am
Buy a 970 engine, turbo that.. On 13th Jul, 2012 Ben H said:
11th Sep, 2009 at 09:10:53am
Keep us updated, sounds very interesting. If these titanium rods are any good it could Id like to know
I seriously doubt it! |
11th Sep, 2009 at 10:01:07am
I like innovation and doing something different.
11th Sep, 2009 at 11:39:30am
thing that gets me and no offence ment, but your in the states how many other 1275 mini's do you know of? why not build the crazyest 1275 for 1380 what ever to race against the yank cars and ricers? big power 13's or 10's on hooser tires longish diff and a k1100 head or a k100 head turbod with all the power you can get? would probably be more fun Drives
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
11th Sep, 2009 at 12:19:18pm
paul its clear why......
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
11th Sep, 2009 at 02:43:49pm
Normally I would agree with you that it's because I'm american, but you have to give me credit where it's due, normally americans like big bore, gas sucking behemoths. Remember the muscle car era....? And thanks to those of you that can see my vision(wil_h, paul wiginton, and ben H primarily). I'm looking for the ultimate of ultimate 850's. And if I can keep up with your 1275's on the 1/4 or the street, whos to argue who has the better motor?
