| Home > Help Needed / General Tech Chat > Cooling issues | |||||||
![]() 465 Posts Member #: 1972 Senior Member Worcester |
11th Sep, 2009 at 04:58:28pm
Hi, having some trouble with my cooling system, car is fine when driving along temp gauge stays at bangon normal, but in traffic it creeps up to halfway between hot and normal, and the other day went right up to hot.
11th Sep, 2009 at 05:04:46pm
first thing i would do is get a proper gauge that will tell you the temp in numbers,
11th Sep, 2009 at 05:09:26pm
Worth a try, but forgot to put when you turn engine off, i can hear the water bubbling and the overflow on the rad pisses water out for a few seconds |
![]() 902 Posts Member #: 111 Post Whore Loughborough |
11th Sep, 2009 at 10:45:37pm
Would it be better to cool the turbo off the output of the rad?
11th Sep, 2009 at 11:08:58pm
bah!
12th Sep, 2009 at 09:18:26am
So do you just run with no water cooling on the turbo, that was my plan today, to disconnect it and see what difference it makes. |
12th Sep, 2009 at 09:46:02am
I feed the hot water out of the turbo back into the top hose. As it is after the thermostat, the pressure is lower and you get a good feed.
12th Sep, 2009 at 09:51:00am
Do you still take the feed from the heater tap? |
12th Sep, 2009 at 10:52:31am
On 12th Sep, 2009 retroracer1380 said:
Do you still take the feed from the heater tap? Yes. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
12th Sep, 2009 at 11:05:22am
I think the problem with the water cooling on mine was because my turbo was up high it could not thermo syphon after shut off, so it just boiled the water in the turbo and chucked it out.
12th Sep, 2009 at 11:25:05am
Ok for pauls idea,
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
12th Sep, 2009 at 11:37:39am
Metro spacer would be the wrong side of the thermostat - needs to feed back in after the thermostat. On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
12th Sep, 2009 at 12:18:07pm
I just cut up a bottom hose to make a top hose with a branch.
12th Sep, 2009 at 12:20:12pm
iirc you can put the thermostat above or below the metro spacer block.
12th Sep, 2009 at 12:40:57pm
Great stuff, i will have a play and see what happens,
444 Posts Member #: 2885 Senior Member |
13th Sep, 2009 at 11:56:54am
Where do people connect the expnsion tank, highest point? Sounds like a good idea.
