| Home > Technical Chat > Gearbox | |||||||
![]() 127 Posts Member #: 1871 Advanced Member Chesterfield, Derbyshire |
14th Sep, 2009 at 06:45:25pm
Ive just bought a metro turbo lump less gearbox, am I right in thinking I can just use say an A+ 998 etc. gearbox, I will be rebuilding it with a minispares straightcut gear kit anyway, does it matter what gearbox I use?
14th Sep, 2009 at 07:11:21pm
yep thats fine, the 998 should hopfully have less wear on the bits you will reuse like the layshaft, and main shaft.
14th Sep, 2009 at 07:20:58pm
Nice one thanks, just wanted to double check before I get one!
14th Sep, 2009 at 07:28:34pm
only thing to look out for is how many bolts hold the main bearing retainer on 3 or 4, the 3 bolt cases are stronger. On 28th Aug, 2011 Kean said:
14th Sep, 2009 at 07:53:48pm
As above,
![]() 41 Posts Member #: 1981 Member the Netherlands |
10th Nov, 2009 at 09:40:53pm
So the DAM2886 box is not a good way to go?
On 8th Aug, 2010 Brett said:
Carl worked my bottom end, cannot fault the workmanship its spot on, a good old chinwag too :) |
