Home > Help Needed / General Tech Chat > Hot starting problem
Hopefully a simple one;
My house mate's stage 1 998 is having trouble starting when hot, now I reckon that the fueling is out, the carb's got a ABD needle, and the plugs were black. We've popped in a new set of BP6ESs and they've helped with the running but it's still struggling to start when hot. I reckon it's the fueling but does anyone have any other ideas?
stefaz
Member #: 1656
stoke-on-trent
has he plumbed the manifold into the cooling system?
Yep, is that likely to be the cause?
Have you tried a little bit of choke? not the fast idle bit, but actual choke? That will tell you if its lean. Try a bit of throttle, that will tell you if its rich
Edited by Sprocket on 14th Sep, 2009.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Rob, is it worth just whipping the dashpot off and checking the jet height with the bridge ?
It does sound like over fuelling to me.
Easy to re-set if its an HIF38 but a bit fiddlier if its an HS4 or H4.
Got a Gunson's if you wanna borrow it.
Is the air filter clear and free from clogging as this will play havoc with mixture even if the jet height is ok ?
Richard.
