| Home > Help Needed / General Tech Chat > Megajolt Meltdown | |||||||
14th Sep, 2009 at 10:31:10pm
I had a few problems with my megajolt at the start of the year. I managed to get it sorted by swapping the edis and havent really thought about it since.
14th Sep, 2009 at 10:45:57pm
what version, 4?
14th Sep, 2009 at 10:50:20pm
I forgot to say its a version 3. It was built by Martin MIllener and says fimware v3.21 on the back. |
14th Sep, 2009 at 10:51:12pm
http://uk.rs-online.com/web/search/searchB...N2003AN&x=0&y=0 Isambard Kingdom Brunel said:
14th Sep, 2009 at 10:51:17pm
http://search.digikey.com/scripts/DkSearch...e=497-2344-5-ND
Edited by Sprocket on 14th Sep, 2009. On 26th Oct, 2004 TurboDave16v said:
14th Sep, 2009 at 11:17:11pm
On 14th Sep, 2009 Sprocket said:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=497-2344-5-ND Its an output driver chip for relays and such. They dont like dead shorts or high current, and that looks like whats happened Probably still works as it looks like its only channel 6 and or 7 thats failed Thats brilliant thanks very much. I tried a search but to be honest electronics isnt a forte! I didnt think my wiring was too bad until this either. I will get one of these ordered along with the holder and get my aunt to sort it out. She used to build circuit boards for a living so shouldnt be a problem. I take it this would affect the user outputs? |
14th Sep, 2009 at 11:21:02pm
On 14th Sep, 2009 Star Mag said:
I take it this would affect the user outputs? Yes, but make sure the problem that caused it has been fixed, before you fit the new chip You should be able to fix that as the chip is mounted in a socket. Just make sure that it is installed the same way, the number 1 pin end is noted by the D shap recess on one end, or in some cases the corner of the plastic case is missing Edit* mind you, the socket has also melted so it would be better if that was replaced too, which is a desolder/ solder job http://www.maplin.co.uk/Module.aspx?ModuleNo=2530 Edited by Sprocket on 14th Sep, 2009. On 26th Oct, 2004 TurboDave16v said:
14th Sep, 2009 at 11:28:23pm
14th Sep, 2009 at 11:40:08pm
I think it melted when i had my original problem. The wiring looked like a snakes wedding. But as you say I will check all the wiring out before I fit the new chip.
15th Sep, 2009 at 10:43:56am
wow not seen that before! AlexF |
15th Sep, 2009 at 07:19:45pm
from autosport.. looks like thats why the chip is on a socket.
15th Sep, 2009 at 10:06:05pm
Cheers for the help guys. I have had a word with a mate of mine that sells adaptronic ecus and he says that its a common fault on them when people wire them wrong so he will be sending the chip over! I can pick the holder up from maplin so should be sorted in no time!
15th Sep, 2009 at 10:15:19pm
yep On 28th Aug, 2011 Kean said:
15th Sep, 2009 at 11:14:00pm
On 15th Sep, 2009 mini13 said:
yep Nope, lol, its this one http://www.maplin.co.uk/Module.aspx?ModuleNo=5502 This is a 7 channel 16 pin chip, And you'll need the 16 way DIL socket The other chip is an 8 channel 18 pin Edited by Sprocket on 15th Sep, 2009. On 26th Oct, 2004 TurboDave16v said:
