Home > Beginners Tech > just removed whole engine
blister
Member #: 2590
Croydon
just removed the whole engine and put exhaust wrap on the turbo manifold what else is worth doing whilst the engine is out ie checking if things are ok, worn replace and stuff like that
also the last owner removed the ecu and i dont think they have blocked everything and changed whats needed could someone possibly give me some help on what is needed to be blocked and changed
AWDmoke
Member #: 713
Western Australia
Check that the clutch is OK and both crank seals. Leave out the 7 o'clock wok bolt. New engine mounts & steady bushes if they show any signs of deterioration. Paint engine.
On 24th Dec, 2008 Nic said:
blister
Member #: 2590
Croydon
checkde clutch its brand new was plannin on painting the engine but cant find the bmc blue any where. Also what is the 7 o clock bolt and why remove it
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
7 o'clock being one round from 6 o'clock - clockwise haha.
The bolt holding the wok to the transfer casing in the bottom left corner, which is a pain to remove with the engine in situ, just makes life easier if you have to remove the wok with the engine in.
Just check for leaks, clean it up a bit etc
*happy*
MONSTER HEDGEHOG
Member #: 4340
sideways, Birmingham
i think this all depends on how far your willing to go.
starting with the basics id replace the diff pin and planet gears as if the diff goes bang it will probobly take the box casing with it, also a selector rod upgraded seal thingy would be a good idea. id also see if the gearbox double bearings started to disintigrate, if you turn the gearbox over while its out of gear and you hear ball bearings rattle around then its very dead *indifferent*
however if you want a engine you can really rely on then puting a central oil pickup pipe and new big and main bearings would be a good start
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol
carl
FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR"
