Home > General Chat > price of fitting valve guides....?
took my head off to find a broken guide at the top side(exhaust)
anyhow, took it to a local place who said they'd do it ,
i took all the valves out etc, and just gave them a bare head,
got a call asking for £110 for fitting 8 bronze guides, reaming out 4 to 8mm,and fitting all of it back together, oh and cutting the seats,
so is £110 a bit too much to be paying for this? or is that a good price?
also the guy said that double springs are over kill and can lead to fast wear on the guides, and cam lobes....? i dont take it past 5600rpm much atall
cheers
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Why did they ream 4 guides out to 8mm? Does sound pricey though
On 30th Apr, 2010 Rod S said:
Gary's description is best
8mm to take turbo valves,
8mm?
isnt that a bit wizards sleeve?
lol, i thought thats what they were...lol
he mic'd them all seprately then reamed acordingly,
i hope.....
On 17th Sep, 2009 mini13 said:
8mm?
i hope.....
8mm?
GaryOS
Member #: 2810
Dublin, Ireland
8mm threw me aswell. I assumed they would be an imperial measurement. I'll check minispares site
http://www.minispares.com/Product.aspx?ty=...GUIDE%20TURBO...
GaryOS
Member #: 2810
Dublin, Ireland
Well minispares say 8mm
But they also say 7.2mm for stanard guides. Surely they're not metric. BL/Austin/Rover/Morris/Whoeveractuallybuiltthemini wouldn't use metric. Anybody know what size thy're supposed to be?
Anyway, if the checked dimensions before reaming then it's not an issue
EDIT: Got there before me. I'm still not convinced though
Edited by GaryOS on 17th Sep, 2009.
pinkyandnobrain
Member #: 2588
Pretoria South Africa
5/16ths ? About 7.9375mm or so.
"Try to take over the world!"
MONSTER HEDGEHOG
Member #: 4340
sideways, Birmingham
sounds possibly reasonable as long as thay do the job right, if your meaning the std turbo double springs then thayre not silly like big isky 220lb type springs so poss worth keeping with 8psi+ trying to open your valves for you.
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol
carl
FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR"
Price sounds OK to me
I'm sure me or steve could have done it for a better price. :)
