Home > Help Needed / General Tech Chat > Where do i get a turbo?
iety7822
Member #: 422
Cardiff, S.Wales
Hi, all of the threads i have read said that the best suited sized turbo for the mini is the T2, which is fitted to the R5GTT which is water cooled. How does this T2 differ from the ones fitted to RS Fiestas and Escorts?
But i also read that the new GT turbo will also fit, is it true? what new cars are these fitted too?
I just need to know where i can get a turbo, so i can start my install!
What about turbo's that are fitted to Turbo Diesels, like the Ford Mondeo they are cheap and plentiful and no one will care if they go missing! what type are they?
the escorts have T3's, and the T2 on the Fiesta has a 3 bolt fixing pattern so is not suitable
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
turbos for diesels are differetnt and gernerally do not work well in petrol applications.
alex
AlexF
and most are not water cooled like the R5GTT
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
not that that matters....
alex
AlexF
iety7822
Member #: 422
Cardiff, S.Wales
what about te new GT Turbo's? i read somewhere that u could use these?
They are fitted to newer cars
Does anyone know about these?
check out the ebay links on this site. there is a GT15 suitable for mini use in there.
iety7822
Member #: 422
Cardiff, S.Wales
I just checked it out and it said that it was removed from a turbo diesel so now im confused, cos you guys said i can't use one off a diesel
dan
Member #: 93
i reckon people have said they are no good because they are 'specc'd' for use with diesel engines etc no with petrol engines
i know they use them on quite a few turbo projects, such as motor bikes etc, the GT15 has to be one of the most commonly used turbo's at the minute, it seems to suit quite a wide range of engines
I wouldn't worry about using a Turbo off a diesel. My mates used a diesel Turbo for the last 3 years on his Mini, no probs !
Phil. *smiley*
iety7822
Member #: 422
Cardiff, S.Wales
so where's the best place to sorce one? do i have to worry about stud patterns or anything?
cheers
