Home > Help Needed / General Tech Chat > t3 turbo elbow bolts
insamoufonyx
Member #: 7071
Nailsea, Near Bristol
Hi all,
what thread are used on the bolts joining the turbo elbow to the t3 turbo and how long are they?
ive tryed m8 and 5/16th's unc and neither feel like they fit correctly.
cheers
have a search. been asked many times
M8 but you will need to retap the threaded holes in the turbo exhaust housing for them to "feel right" - just think how many year's corrosion is in there.
For length, just measure the thickness of the elbow at each bolt hole and add 15 - 20mm.
EDIT - I should just add, the fact they are M8 is down to Garett, virtually everyting else on a Mini is imperial (apart from some of the very last ones).
Edited by Rod S on 18th Sep, 2009.
insamoufonyx
Member #: 7071
thanks rod
yup, agree with rod, M8 *smiley*
Simon
Member #: 1865
Norwich, Norfolk
M8, 25mm, 60mm, 80mm lengths should do it
