Home > Help Needed / General Tech Chat > inner cv joint, slipping.
mayoturbo
Member #: 1395
chepstow
I have a problem with the metro turbo. The potjoint is coming out(bit in the boot). When the car is on the ground I can feel the edge of the bearings.
This happened after lowering the car, so I raised it back up. Car drives ok untill a corner or the engine is under quite abit of load. I thought the inner cv was just worn(this was before I realised the potjoint is barely in) so have replaced it and it still does the same thing.
Could this be something to do with the diff? bent driveshaft? outer cv?
I've had this on mettys, they seem to do it if you really slam them to the deck.
I've also had this, try blowing up the susp a bit, cured it for me.
mayoturbo
Member #: 1395
chepstow
How do the cup cars run so low? I have raised the car now its only about 15-20mm lower than standard
the cup cars have special shafts, pretty sure they are longer.
you could get 2 sets of shafts and cut and reweld them, there is a guy on 16v mini that does cut and shut shafts for around 30-40 quid a pair. user name Aband
Oh also check your engine mounts.
Edited by Joe C on 18th Sep, 2009.
manifold
Member #: 1734
Lancaster
agreed check your engine mounts, especially the offside back one where the steel plate can (and does) shear.
Can you rock the engine forwards nough to make the diff slightly higher?
Paul
MONSTER HEDGEHOG
Member #: 4340
sideways, Birmingham
i seem to remember somone saying that raising the engine cured this problem, i think it was in retro cars, possibly ian hargreves of avonbar?
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol
carl
FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR"
