Home > Help Needed / General Tech Chat > Fuel pump knackered?
n.g.l.
Member #: 181
Chard, Somerset
Mini has developed a problem:(. Under boost, whether it's at 10psi or 20psi, between 5-10 secs of wide open throttle, the mixture goes lean from 12.5:1 to right off the scale. So far, I've pulled the carb, checked the little gauze which was clean and checked the height of the float, which is set at 1mm below the level of the base. I've checked and cleaned the pump prefilter and I've replaced the plugs. None of the above have cured the problem. My thoughts are it's a fuel starvation problem as it comes onto boost O.K. then shuts down after a few seconds. The next step is the fuel pump I guess, can anyone confirm what I'm thinking or is there somthing else I've over looked. Forgot to mention that the regulator is set 3.5 psi at idle and rise uniformly withe boost.
mine did this the pump became very noisy and packed up not long after.
if your pump seems good i would look for crap in the tank / pump feed possibly even main fuel line to the front it sound like its not getting enough fuel
edit: i really should read more than the first line*happy* how noisy is the pump?
Edited by Brett on 20th Sep, 2009.
n.g.l.
Member #: 181
Chard, Somerset
I've heard noisier pumps.
Mr Joshua
Member #: 1954
Luton Bedfordshire
If you have the part throttle lean off pipe fitted check it for holes. A pin prick in this pipe will cause exactly what you are describing.
Spent months chasing my own arse because of this pipe. *angry*
Edited by Mr Joshua on 21st Sep, 2009.
Own the day
n.g.l.
Member #: 181
Chard, Somerset
Part throttle pipe blanked off.
Mr Joshua
Member #: 1954
Luton Bedfordshire
If its a Metro pump I have spare.
Own the day
