| Home > Help Needed / General Tech Chat > carb to inlet manifold | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
21st Sep, 2009 at 07:22:35pm
I've come across a problem I really wasnt expecting today.
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
21st Sep, 2009 at 07:24:58pm
Something definitely isn't right there - if thats an HIF44, the throttle quadrant should be on the other side. On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
21st Sep, 2009 at 09:23:02pm
Is that an N/q carb?? On 11th Feb, 2015 robert said:
21st Sep, 2009 at 10:25:14pm
It's on the wrong side mate. |
22nd Sep, 2009 at 08:22:52am
Looks like an N/A carb to me. Have you converted it Zero? If something is worth doing, it's worth doing half of. |
22nd Sep, 2009 at 09:42:59am
When I test ran my engine with a carb to confirm the dual widebands were working, I had exactly the same - N/A carb on a turbo inlet manifold... Schrödinger's cat - so which one am I ??? |
22nd Sep, 2009 at 10:32:11am
yes it is an N/A carb, not converted yet but I do plan to as it was running sweet as a nut on my N/A engine.
23rd Sep, 2009 at 09:51:06am
any more thoughts on this? maybe some piccys of yours.
Edited by Simon on 23rd Sep, 2009. |
23rd Sep, 2009 at 10:08:45am
the turbo arm is almost round in shape not ovaluu Yes i moved to the darkside |
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
23rd Sep, 2009 at 10:26:00am
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2878 in that thread you will see the difference in the throttle, as brett says pretty much round rather than oval On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
23rd Sep, 2009 at 10:28:54am
I had this problem when I modified my carb to take the TPS sensor. As Brett says the arms are very different, I'd take a punt and say the turbo one is designed for a more progressive throttle response than the NA one, possible due to the increase in mid-range torque. One option is a NA MG Metro manifold as they have a lot more clearance. I think I ended up going for a combination of: spacer, turbo throttle linkage & filing the manifold slightly, as it was a blooming tight fit. Isambard Kingdom Brunel said:
