| Home > Help Needed / General Tech Chat > OT: Possible ECU Damage | |||||||
21st Sep, 2009 at 08:31:36pm
After attempting to get my 318i running after a year of neglect I began diagnosing what is wrong with it. I had to rewire the fule pump as I ran it for months with a wanked pump that had no strainer and melted some wires. I have continuity between the ECU and the relay, continuity between relay and pump, permanent live to the relay and earth to the relay.
Gary's description is best |
21st Sep, 2009 at 09:12:37pm
Quite possible.
21st Sep, 2009 at 09:27:31pm
Thanks Colin. I was thinking about sourcing another one and this confirmed my decision
21st Sep, 2009 at 09:33:09pm
21st Sep, 2009 at 09:34:01pm
Well and truely! I was planning a road trip this weekend but it's looking less likely now On 12th Nov, 2009 Paul S said:
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
22nd Sep, 2009 at 08:34:37am
A friend at work had exactly the same thing happen to his. On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
22nd Sep, 2009 at 10:46:46am
The ECU is directly below the battery, although inside the car. The battery in my car didn't have a plastic tray under it and it corroded. Once it corroded all the way through the body it allowed water and possibly battery crap to leak onto the ECU. It was the side facing upwards that suffered so badly. That's what seemed to happen anyway.
