Home > Help Needed / General Tech Chat > Hypatec pistons...... Any good?
mikemph
Member #: 449
Oxford
I have seen a few people here have bought hypatec pistons..... are they any good when used in turbo/supercharged applications.
I thinking of going doen the 1360/1380 supercharged route.
alot (well a few) on here rate the hypatec 's quite high, and my machine shop use them in some of there rebore kits, they rate the actual piston very highly but hate the rings they said there shite, and also said id be a fool to run any boost with them
i bought cast omegas, they are rated highly but cost 300quids
I've got them, the 73mm ones.
It will be a couple of weeks before they run in anger though, so far the engine has only been test run with no load.
The 73 and 73.5 are a very good design of pistion (oil drain holes instead of slots) and quite substantial at the crown - fortunate as I had to machine a fair bit out to get adequate dish volume (they are intended for high compression engines so come with a small dish).
The ring pack I got was a reputable make (Hastings) apparently used a lot for high performance applications in the USA, no absolute proof yet but a reasonable sign of quality was that evey gap was spot on when I tried them in the bores, not one needed adjusting.
I bought it all from Australia so maybe another make of rings is being sold over here.
However, only time will tell.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
I got the 1098 +060 pistons with slots. The pistons seem of good quality but the oil cotrol ring (well, the bottom one, whatever that's called) was a bit ropey. There was a weird hexagonal part of it that confused me. I had no idea wheather or not I assembled that ring correctly
On 30th Apr, 2010 Rod S said:
Gary's description is best
mikemph
Member #: 449
Oxford
hhmmmmm still not sure if I should just bite the bullet and spalsh out a little more and go for cast omega pistons like a few others have recommended and tried and tested. Need it to be a fairly reliable daily drive for work.
like i have read a good few times...
cast omega's are brilliant,... forged fit and forget!!
i couldnt quite stretch to the forged though :(
mikemph
Member #: 449
Oxford
I see that MED do them for £280 and minispeed something like £250+vat so not too bad. But I think MED have more selection of dishes and sizes
minispeed is one place i never think to look, but MED had mine to my door in less than 18 hours..they was very good to talk to on the phone aswell
mikemph
Member #: 449
Oxford
Well depending what prices I get back for MED for all the rebuild parts thats where I will be buying from them.
I am guessing that minispeed will be cheaper, going by piston prices but I will see. I guess the parts MED sell would maybe be of higher quality???
Users viewing this thread: none. (+ 2 Guests)
