| Home > Help Needed / General Tech Chat > Looking to get some fabrication done, anyone on here up for doing it? | |||||||
297 Posts Member #: 2276 Senior Member sheffield / derby |
22nd Sep, 2009 at 08:51:56pm
Hi all I'm looking to get one of these made
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
22nd Sep, 2009 at 08:53:03pm
fastcarl is probably your man for that. On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
22nd Sep, 2009 at 09:43:32pm
I'd second the fast carl recommendation. he made a top job of my pulley On 11th Feb, 2015 robert said:
22nd Sep, 2009 at 11:42:39pm
can i ask what its for? "Turbo's make torque, and torque makes fun"
22nd Sep, 2009 at 11:52:35pm
you certainly can
23rd Sep, 2009 at 12:04:03am
cool, good luck "Turbo's make torque, and torque makes fun"
23rd Sep, 2009 at 09:17:01am
Luke, Check your float bowls the stub might need to be at an 45deg angle to keep them level, mine did when my converter was made. I run a supercharger and I don't care the TB is on the wrong side.
23rd Sep, 2009 at 09:52:45am
Hi Graham
23rd Sep, 2009 at 11:58:43pm
bump |
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
25th Sep, 2009 at 03:40:11pm
so this is to run 1 bike carb (direct replacement so so) instead of doing the bog brothers inlet and twin bike carbs?
969 Posts Member #: 47 Post Whore Not very sunny swanage |
25th Sep, 2009 at 08:39:53pm
have a looksee round a earlyish k series metro, they had something that could easily be modded to do what your trying to do iirc......
And on the 7th day........... God created turbochargers! |
25th Sep, 2009 at 08:45:45pm
You got a dxf, drg or dwg file of that drawing 998turbomini25? I can't open 3d models of parts. I'll have a look at work to see if we have any tube and plate. On 19th Jan, 2010 wil_h said:
25th Sep, 2009 at 08:47:58pm
actually im wrong, the bit im thinking of is angled and on the other side of the carb.... whoops.......
28th Sep, 2009 at 09:28:42am
you got this sorted now? ive had a hunt round and ive found some tube thats ever so slightly over, (id = 44.2mm iirc) must have some plate kicking around somewhere, so can knock something up if your still in need...... let me know...... And on the 7th day........... God created turbochargers! |
28th Sep, 2009 at 03:54:55pm
cheers nutter driver that would be grand if you could as i stated above i will happily pay for materials and your time.
8th Oct, 2009 at 10:55:04pm
hiya nutter driver have you had any luck making this at all??
