| Home > Wanted > ALUMINIUM hif44 carb spacer... | |||||||
297 Posts Member #: 2276 Senior Member sheffield / derby |
24th Sep, 2009 at 11:10:33am
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
24th Sep, 2009 at 01:14:44pm
Think I have one.Will check tonight. 'Where does the engine go?' |
24th Sep, 2009 at 06:28:47pm
If theres an interest, I can get some made. Are they just ally versions on the black plastic ones? Edited by Jason G on 24th Sep, 2009. On 19th Jan, 2010 wil_h said:
24th Sep, 2009 at 06:45:01pm
Are they lighter? lol On 11th Feb, 2015 robert said:
24th Sep, 2009 at 06:47:18pm
whats wrong with a plastic one? they do the job nicely |
24th Sep, 2009 at 06:52:51pm
Was thinking the same thing...but if it sells................
On 24th Sep, 2009 iain said:
whats wrong with a plastic one? they do the job nicely On 19th Jan, 2010 wil_h said:
24th Sep, 2009 at 07:02:04pm
On 24th Sep, 2009 steve1275 said:
Think I have one.Will check tonight. Thanks would be good if you do have one, let me know.. The reason i want an aluminium one is i can use it as the flange for this http://turbominis.com/forums/index.php?p=vt&tid=315845 Im not sure a plastic one will work aswell ![]() that is When i hopefully find someone to weld a bit of pipe on for me
Cheers luke |
24th Sep, 2009 at 07:02:10pm
Luke needs to make a flange to mount his bike carb On 11th Feb, 2015 robert said:
24th Sep, 2009 at 07:13:52pm
to be honest, some simple hand tools and an offcut off ally plate would make you something up Edited by iain on 24th Sep, 2009. |
24th Sep, 2009 at 08:08:38pm
I thought the idea of the plastic one was that it was a heat insulator -the alloy one will be a heat conductor,surely ?. |
24th Sep, 2009 at 08:28:00pm
you have pm 998 'Where does the engine go?' |
