| Home > Help Needed / General Tech Chat > Termostat blank / bypass | |||||||
24th Sep, 2009 at 11:04:45pm
Im running an electric water pump and it will be switched so that it will still run after the engine has been turned off.
784 Posts Member #: 912 Post Whore North Yorkshire |
24th Sep, 2009 at 11:31:47pm
SECTION TWO: OPTIONS FOR PUMP CONTROL
I drill holes in everything..! |
25th Sep, 2009 at 08:26:18pm
Chears si.
29th Sep, 2009 at 03:53:34am
On 24th Sep, 2009 cossierick said:
Im running an electric water pump and it will be switched so that it will still run after the engine has been turned off. The question is, shall i just leave the thermostat out or should i put one of those blanking sleves in? Rick If you do remove the thermostat a blanking sleeve would be advisable.. website:- http://www.terryhunt.co.uk
29th Sep, 2009 at 11:15:46pm
Whats the benifit of fitting one ??
29th Sep, 2009 at 11:26:26pm
At a guess, I would imagine you would get alot of cold water from the pump going straight back into the top of the rad rather than through the block where it absorbs heat. That is if one isn't fitted On 12th Nov, 2009 Paul S said:
Gary's description is best |
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
29th Sep, 2009 at 11:29:03pm
Yes I was told that from steve at MED, he said without the blanking sleeve cly 4 runs very hot and you can crack the head. On 25th Sep, 2009 mini13 said:
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
