| Home > Help Needed / General Tech Chat > Won't start | |||||||
617 Posts Member #: 6558 Post Whore Pueblo, Colorado, USA |
26th Sep, 2009 at 04:56:53pm
Okay all, here's my problem. I have replaced a large number of parts on my mini, to include: head, clutch cover, clutch arm, clevis pins, slave cylinder, and intake(I have cut off the old intake and put in a minispares aluminum one). Now I have got it all back together and the car will not run. Rather, it ran for about 5 minutes while I was figuring out mixture etc... After shutting off now the car will not turn over. Now, there are two problems, the wire that goes from the coil to the dizzy broke, and I am now using a longer one from a different car, and the coil is all of a sudden getting extremely hot. Is it possible that the coil dumped on me, or that the wire is too long, or both? Is it possible it's something else? There was fuel coming out of the overflow, and after playing with the mixture for a while there is no longer. Also, it's a 1978 Mini 850(with the 850 still in it).
26th Sep, 2009 at 06:37:42pm
What colour is the wire that you have fitted from the other car? It could be that you have got a resistive wire from a more modern car. This might cause the coil to heat up.
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
26th Sep, 2009 at 10:40:49pm
id see if you can turn the engine over by hand of pushing the car in gear, if you cant then either you tightened a slave cylinder bolt after the car was running and its to long, you have a stuck starter or you forgot to put oil in :$
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
27th Sep, 2009 at 06:07:15am
Okay, thanks for the replies.
27th Sep, 2009 at 09:19:26am
Engined not earthed properly or solenoid. On 19th Jan, 2010 wil_h said:
1050 Posts Member #: 764 Post Whore Staffordshire |
27th Sep, 2009 at 10:09:00am
Flooded? |
28th Sep, 2009 at 03:09:28pm
I'm going with flooded. She starts fine now, no fuel spillage or anything.
