Home > Help Needed / General Tech Chat > Carb problems!
insamoufonyx
Member #: 7071
Nailsea, Near Bristol
Hi all,
im having some fueling issues, il explain with a picture:
When A the presure tube to the regulator, B is the fuel input from the presure regulator, C is blanked off and the jet hole inside is blocked fuel comes out through point D - which means when its connected to the front of the carb its just pissing into the cylinders.
Edited by insamoufonyx on 27th Sep, 2009.
stuck float jet
insamoufonyx
Member #: 7071
how do i go about fixxing that then?
chinlesswonder
Member #: 1192
In the garage......again!!
take the bottom off the carb and clean it all out
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
insamoufonyx
Member #: 7071
already had a look but its pretty clean, il go mad with carb cleaner and seee what happens :)
Mr Joshua
Member #: 1954
Luton Bedfordshire
Blank of pipe D at both ends you can live without this. A mate had the same issue this very weekend told him to remove and blank that pipe (plenty of threads on here about it) and his engine is now running sweet.
Own the day
chinlesswonder
Member #: 1192
ah yes, its the throttle lean off pipe syndrome, mine wouldn't run with it connected at all, had to blank both ends
insamoufonyx
Member #: 7071
ok, tryed that, will thouse blanked off it then leaks through into the presure return from the plenum to regulator
