Home > Help Needed / General Tech Chat > Metro Turbo clutch query
antman
Member #: 358
Snetterton, Norfolk
Well i've been trying to get my 1983 Mk1 metty turbo sorted out today but i've come across a problem.
Runs and starts fine tried the clutch and it engaged but didn't return. After trying a couple of times realised there was a leak.
Not having played with a metty before there appears to be an intermediatry piece inbetween the master and slave cylinders and its this thats leaking.
I think the rest of it is just from sitting but the leak in this junction box is annoying me. Gotta go get a haynes manual tomorrow but if anyone can suggest what its called in the meantime i would be most grateful.
round thing?
if so its a clutch damper.
It's a sort of compensator Ant. You can remove it and pipe straight to the cylinder if you need to.
antman
Member #: 358
Snetterton, Norfolk
thats the kiddy. Are they still availiable from anywhere?
antman
Member #: 358
Snetterton, Norfolk
Thats it mini13. I had compensator in my head for some reason though.
http://cgi.ebay.co.uk/Austin-Rover-MGF-Clu...emZ200343604050
http://cgi.ebay.co.uk/MGF-TF-NEW-CLUTCH-DA...emZ270461239108
antman
Member #: 358
Snetterton, Norfolk
Cheers all will see if i can find one, if not i'll plumb it in directly.
Star Mag
Member #: 375
Leicestershire
I may have one of these in the garage attached to a slave will have a look tomorrow.
