Home > For Sale > My K 16v 1293cc Engine - SOLD
antman
Member #: 358
Snetterton, Norfolk
Well guys, I never thought the day would come when I’d be doing this but I am offering for sale my K headed motor.
I’m going to offer it to you all as a complete unit first, then if I don’t have any interest then I’ll break it.
Spec as follows:
K100RS 16v cylinder head converted to suit mini block.
1293cc Block converted to suit the cylinder head.
21253 pistons with valve cutouts (big enough for sc’s sprint cams)
11:1 Compression ratio
Polished cam cover
34mm Throttle Bodies
SC 34mm Ram pipes to suit the above.
Rebuilt Standard Gearbox with hardened diff pin. 3.44:1 CWP
MED Ultralight Flywheel with Uprated friction plate and orange diaphragm
My own pulleys and conversion kit – top pulleys are adjustable.
SC Typhoon ECU with preloaded base map to suit engine spec.
SC Road spec wiring loom
SC Trigger Wheel kit
SC K Exhaust manifold
RC40 exhaust modded to fit (was only a 1 ¾” modded to 1 7/8”)
Fuel Pressure regulator
SC Water outlet and thermostat
SPI fuel tank with big Toyota Fuel Pump (good for 5 bar)
That’s most of what I can think of at the moment and I’ll add more if I think of anything.
Only for sale due to me buying a Mk1 Metro Turbo off JohnK and I would get bludgeoned if I was to fit this into it!!! So standard is the way forward, just gotta remember how to adjust tappets!!! Its been a long time.
This package is basically all you would need to get a K engine working and in your car.
Looking for offers around £3k.
Engine is based at home at Wymondham, Norfolk.
Couldn't find many pics at the moment but this one will give you a general idea.
The engine has done approx 6 miles since build and all the bugs have been ironed out, rusty shell forces sale!
Edited by antman on 7th Nov, 2009.
That's a nice looking motor.
My brother used to live in Wymondham. You have to drive 100 years back in time to get there....
Shame you've decided to sell!
Ironed out all the problems in 6 miles...you've done well! :)
antman
Member #: 358
Snetterton, Norfolk
I've only decided to sell so I can concentrate on the metty turbo. Trying to keep it all intact instead of tearing it out to go in a mini!
And the way I look at it is that I can always throw another one together now I know all the tweaks should I get bored with the metty!
Put it in the Metro! Have a first!
Just keep the old enginge so it can be put back to factory.
antman
Member #: 358
Snetterton, Norfolk
Nah, i have an originality agreement with the previous owner to keep it standard.
Thats what i was looking to do until i came across the Turbo! I was after a beige 2 door base model metro to shove it in with national trust stickers and all.
I undersandt that, there's only about 35 MK 1 metro turbos left.
I know where there's another in need of an engine though.... *Yes*
antman
Member #: 358
Snetterton, Norfolk
And how many in left hookers? Can't be many!!
Not many at all I would expect. Still, at least I have a rearer metro than that *wink*
ERA ANT
Member #: 4179
Cumbria
What type pistons are fitted to the engine mate?
Do it right the first time and make it mint!!!!!!
