Home > General Chat > Is it possible to get a single line 7/8" brake master?
mpe
Member #: 4743
Hi all.
A bit of searching on this forum suggests that a good m/cyl bore size to use is 7/8" (for use with metro four pot calipers). It would also seem that the only way to get 7/8" might be one of those fancy aftermarket pedal boxes with thier associated m/cyls.
I'm hoping to keep it cheap and simple, so any advice along these lines MUCH appreciated.
I've been trying to use a 0.70", but it doesn't give much pedal at all.
Thanks
Matt
Australia!
Scruffy
Member #: 328
Seaford Rise, South Australia
What like this?
On 5th Sep, 2011 Vegard said:
i have a 1" m/cyl if its any use to you.
mpe
Member #: 4743
Thanks for the replies. I think going to try to stick with a standard Mini master cylinder, which means 0.75" at the most. Thanks again.
I have a 7/8s master cylinder on mine
It is horrid and will come off when I have spare pennies
mpe
Member #: 4743
Nic, what size will you be going to?
Word on the street in aussie mini circles is that 0.75" is best.
3/4's, ahh so 0.75"!!
