Home > Help Needed / General Tech Chat > mayo in rocker cover
washed mini and done the weekly checks to find a rocker full of mayo and the water and oil needed about half litre each
i though head gasket but ive done searches and it could me the 10 min jurneys twice a day i doo in it. Ive had it a year and not had this before whats your thoughts?
Do you think an oil n filter change could cure it? Is it worth ripping the head off with the rr and rwyb weekend looming ?
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Run an oil flush through it and then change oil and filter. It is most likely due to short journeys and you can check for definate if you start with a clean system and keep an eye on oil and water
On 30th Apr, 2010 Rod S said:
Gary's description is best
its just where the condensation in your engine go's to the highest point,
it happens to me,i dont use it a hell of a lot nowadays ...
MONSTER HEDGEHOG
Member #: 4340
sideways, Birmingham
half a litre of missing water id expect on an open system, if your running a closed system ie metro/ mpi expansion tank id be concerned. the oil probobly went out your exhaust on all the cold starts and driving, so prob nothing to worry about
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol
carl
FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR"
turbominivanman
Member #: 1504
Westbury, Wiltshire
As you suspected, most likely the oil's not getting up to temperature enough to drive off the water vapour from combustion.
I can't stick the stuff as the emulsions that enter the oil can't do much good for bores and bearings.
It's worth making sure the top end breaths as much as possible either into a catch tank or by having a couple of small K&N filters off the rocker cover and transmission casing.
Could try upping the thermostat to an 82 or an 88 and giving it an oil & filter change accompanied by a couple of 20-30 mile journeys to get it really warm.
See you at the RR.
Richard.
i bet you are using duckhams oil
if you are this is the cause
yes*happy* do you think i should use another brand? or thinking about it wouldn't a thinner oil warm up faster?
well theres your problem, its well known
change the oil for some 20/50 another brand .......say coma oil in the yellow bottle
duckhams is recycled oil.
its ok to flush you engine nothing more!
philc
Member #: 1346
bromsgrove
i also have mayo in my rocker, this is something i have not had before. I changed the oil as the oil on the dipstick was a light green. i changed the oil and there was a green film ontop. now i have mayo on the rocker cap. just to be sure this will not be the head gasket? i did use duckhams but have changed it to comma
i have used duckhams im my minis since i can remember, i never knew it was recyled either i will give coma a whirl if i can find some cheers Benross!!
i am not down on power this time, last time i lost alot of power, mind you i did have a burnt valve seat last time too..
Edited by Brett on 11th Oct, 2009.
h4887
Member #: 2404
Braintree, Essex
I used to get this very badly in a HC Viva. I made a sort of tea cosy to go over the rocker box and that cured it completely.
Geoff
duckhams is a high detergent oil
h4887 in answer to your question if your engines runnning right! it will be the residues from the duckhams left in
it will clear in a few oil changes
h4887
Member #: 2404
Braintree, Essex
What evidence have you got for this?
Geoff
abit of thread excavation,
since the rwyb weekend the mini developed a nice missfire at part throttle and an unhealthy drinking habit, then later would fire up on 2 cylinders with the other 2 coming online about 20 seconds after, this was the inner 2 cylinder wetting the plugs
today i pulled the head, it had blown between 2+3 into the water jacket, this is the 2nd time this has happend now, the head will be skimmed and refitted with a bk450 this time, i have a couple of questions though how likely is it that this blowing has burnt away some of the block ( enough to make it unflat and effect the gasket seating) and the second is in regard to a picture i dont have on me so ill aske in the morning,
cheers
