| Home > Help Needed / General Tech Chat > help please | |||||||
13th Dec, 2004 at 01:07:51pm
ok so i going along the m25 at about 70 and all of a sudden car starts backfiring and juddering whenever i put my foot down it was just in 4th but then in every gear, cant go above 30 now so pull over shitter, problem is in neutral the car revs ok bit of smoke and some liquid (fuel vapour?). me thinks its the coil as i did have a similar problem when it went to minispeed, fuel regulator is new and there are no leaks, any ideas?, is there a 'good' coil to buy fed up of buying new ones, any info would be great thanks |
13th Dec, 2004 at 01:09:54pm
also quick question, the t piece that comes out the turbo that has a feed to the actuator on one side and a bit of pipe going nowhere on the other side should this be blocked up? |
Site Admin 6295 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
13th Dec, 2004 at 01:14:26pm
sounds like coil / plugs / leads to me.
13th Dec, 2004 at 01:15:25pm
dashpot oil?
13th Dec, 2004 at 01:19:15pm
cheers guys, i thought the bleed valve went between one side of the t piece and the actuator leaving the other side of the t to have the blocked up bit of pipe. |
13th Dec, 2004 at 09:11:46pm
put a bleed valve anywhere u like (within reason) lol.
14th Dec, 2004 at 01:36:52pm
hi gav, get hold of the demontweeks book, in there are two superb coils wich are more than up for the job rather expensive though but fit it and forget it. they are in the blue book page 185
14th Dec, 2004 at 02:56:07pm
bog standard metty one, 12v for leccy ignition will last years and years. if yours is going wrong then there is something else a miss.
14th Dec, 2004 at 03:15:45pm
iain you are right buddy i had a bad run on coils once.
14th Dec, 2004 at 03:26:05pm
Go for something like a lucas one so you can hope for a good quality one |
14th Dec, 2004 at 03:33:24pm
thats true iain
14th Dec, 2004 at 03:53:20pm
yeah but surely if you are having problems with a strong enough spark using higher boost then really you need to be looking into different plugs not different coils?
Edited by Tom Fenton on 14th Dec, 2004.
14th Dec, 2004 at 04:05:08pm
Thats true Tom, the plug grade may be under doubt ? or just may be they have just give up, worn out ?
14th Dec, 2004 at 05:27:48pm
just noticed all us 3 are relatively local. going to the dreaded meadowhall tonight crimbo shopping!!! |
14th Dec, 2004 at 05:44:54pm
iain, good luck buddy i snaked out of that one over 10 years ago, i would rather be in the garage if not their, "in the pub"! proping the bar up
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
14th Dec, 2004 at 07:22:30pm
On 14/12/2004 15:33:24 benross said:
thats true iain but higher boost figures puts big demands on the whole coil scene may be not in gavs case though ? BENROSS: I have been a motorcycle mechanic for well over 20 years and I think I know a fair bit but am puzled by what extra demand on a coil more boost will cause? |
14th Dec, 2004 at 08:30:47pm
cheers for the input guys, i will try a new coil asap and see if it works, someone also suggested it could be the alternator, the plugs and leads are all brand new i'll just have to see i guess, thanks again for the advice
14th Dec, 2004 at 09:31:29pm
Allan,
14th Dec, 2004 at 09:37:17pm
On 14/12/2004 21:31:29 benross said: Allan, Well if you run a normally aspirated engine no problem there, if the entire stock ignition department is new or nearly new the system should run fine, say motorcycles as there aren?t too may blown ones. What forced induction does basically as you will probably know is raise the cylinder pressure thus the spark has a harder time jumping the gap (it dies under pressure) We are talking boost say 16 to 20 psi and more, the coil has to draw slightly more current up to its limit say 3.2amps nominal ignition until it can draw no more then intermittent spark misfire ! Occurs, especially if the stock ignition components are worn. Hence a better approach to upgrade the ignition system would make sound judgment. I have been a design Engineer for 30 years this coming February Hope this puts you in the ballpark Allan. Regards BENROSS:
14th Dec, 2004 at 11:38:01pm
Watch out running uprated coils on the stock ignition module... I know of one 'well known' fella who uses nitrous on his mini has reverted back to using STOCK coils on his mini (the s in coils should give you a hint).
15th Dec, 2004 at 09:40:15am
AAAAARRRRRGGGGGGHHHHHHH!!!!!!! I hate that place.........you should have dropped the mrs off and then come up the road for a cup of tea and a look at a mini......!!!!
15th Dec, 2004 at 10:02:53am
T Dave thats true also buddy, most of the problems arise when ignition components are clapped out compounding things.
15th Dec, 2004 at 12:01:39pm
ben I may have to take you up on that sometime, be good to have a ride in a turbo mini, might get me motivated to get mine finished.
15th Dec, 2004 at 04:19:54pm
anytime tom
