| Home > Help Needed / General Tech Chat > MOT related question | |||||||
![]() 299 Posts Member #: 2814 Senior Member Mansfield - Notts |
12th Oct, 2009 at 04:33:21pm
Hi all, as some of you may have read, my car failed its MOT today on a few things, one being a worn wheel bearing.
12th Oct, 2009 at 04:37:26pm
The only special tool you need to do the ball joint is a 1 1/2" socket. You can get these for a few quid. Always worth having in your toolbox. If something is worth doing, it's worth doing half of. |
12th Oct, 2009 at 05:09:55pm
as john says get the deep socket though makes it easyer, ive had similar before my tester took me down the pit and pointed it out and said he cannot fail me for it but it needs to be done mine was a splitting subframe mount he missed on the test but spotted on the retest
Yes i moved to the darkside |
12th Oct, 2009 at 05:47:41pm
You can get the socket for about £6 in halfords so easy to get hold of. |
![]() 2102 Posts Member #: 432 Post Whore Swindon |
12th Oct, 2009 at 07:12:16pm
if you know it needs doing then why not do it. From experience, do it as soon as you know it needs doing.
12th Oct, 2009 at 07:31:10pm
I believe he can fail it on other problems that didn't appear the first time. Most just advise you.
On 19th Jan, 2010 wil_h said:
12th Oct, 2009 at 08:22:56pm
just fix it. easier and safer. no longer a series, but still 1.3 turbo.
12th Oct, 2009 at 08:31:54pm
The retest specifcally only looks at the things it failed on. Had to do two of these rescently. It says so on the fail sheet I think....
12th Oct, 2009 at 08:42:55pm
Taa lads, the intention was to always swap it, just didn't know wether I could get it tested before swapping it and still pass.
12th Oct, 2009 at 08:47:43pm
i'd fix it anyway;
13th Oct, 2009 at 11:08:36am
If your going to give him the job anyhow point it out to him and ask if he can do it pre retest just to get him onside, also shows him your not willing to try and pull the wool over his eyes.
Own the day
13th Oct, 2009 at 11:30:59am
On 13th Oct, 2009 Mr Joshua said:
I have a good relationship with the garage that tests all my cars based on this principle. I find that's the most important thing at MOT time. My local tester is quite forgiving and will often advise me on what he wants to see for a retest to answer questions up front On 11th Feb, 2015 robert said:
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
13th Oct, 2009 at 11:47:36am
I have a good relationship with the garage that tests all my cars based on this principle. I find that's the most important thing at MOT time. My local tester is quite forgiving and will often advise me on what he wants to see for a retest to answer questions up front it makes life easier still, when your uncle own's 4..... On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
13th Oct, 2009 at 04:19:19pm
Well I swapped the ball joint today, it was a shit load easier then I thought it was going to be which was good. The ball seat didn't want to come out so they had some heat to fetch those out, bastards.
13th Oct, 2009 at 06:04:51pm
well done,
