Home > Help Needed / General Tech Chat > Air leak
Alex1340
Member #: 111
Loughborough
Hi guys.
The vac line for the brake servo is letting air in. I've coverd the thing in sealant for now but it's not a good fix. Any one come up with a good fix for the problem?
Thanks
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
assuming its a temp fix, duct tape may get you out.
it does see .8bar of vac at times so a new line is the obvious and best solution.
if its split, then cut it and stick, in s straight joiner.
Mr Joshua
Member #: 1954
Luton Bedfordshire
The pipe itself or at a join? if its where it pugs into the servo drop the ruber in boilinb water and reifit. helps regain its shape.
Own the day
if a hose is leaking, change it !
Alex1340
Member #: 111
Loughborough
It's the connection in to the servo. The rubber seal is leaking.
Mr Joshua
Member #: 1954
Luton Bedfordshire
put the rubber in some hot water.
Own the day
turbominivanman
Member #: 1504
Westbury, Wiltshire
I like the hot water tip - that needs to go to the thread on 'top tips'.
You could just buy a new seal, they're available from Somerford.
Or alternatively, just clean thoroughly with thinners and then seal it with an industrial adhesive such as Sikaflex 221, available in a cartridge from Sika, Welwyn Garden City or from most vehicle paint and re-finishing suppliers. Its bloody marvellous stuff and I've used it alot on the van. I wouldn't use silicon sealant if you can avoid it.
Richard.
