| Home > Help Needed / General Tech Chat > LOCKED BRAKES | |||||||
556 Posts Member #: 7029 Post Whore Wickford Essex |
12th Oct, 2009 at 09:10:34pm
hi all
12th Oct, 2009 at 09:18:07pm
I have had a brake bias valve go funny and lock the rears on.
12th Oct, 2009 at 09:23:25pm
i,ll take a look , cheers mate
12th Oct, 2009 at 09:23:27pm
oops double post, skool boy error Edited by EssexSteve on 12th Oct, 2009. |
12th Oct, 2009 at 11:09:54pm
pushrod from pedal to servo or servo to master cylinder is too long holding the master cylinder slightly closed. as the fluid heats up it expands, has nowhere to go so the brakes lock on. This is a really common problem with aftermarket master cylinders on the 16vminiclub. perhaps you have missed an ajsutment somewhere or a spacer washer or some such, either way, check it out. Edited by evolotion on 12th Oct, 2009. turbo 16v k-series 11.9@118.9 :)
13th Oct, 2009 at 08:55:33am
its a bog standard metro turbo havnt touched the brakes , drove it home 100 miles no problems.
13th Oct, 2009 at 11:00:09am
You are already hooked! your sole elongs to TM now Own the day
298 Posts Member #: 1357 Senior Member telford,shropshire |
13th Oct, 2009 at 12:12:58pm
sorry to hijack, but i am having the exact same problem. when driven around for a while they lock on solid!!
'always keep a spare shot for a stray bird' |
13th Oct, 2009 at 03:17:52pm
We had a similar problem with the TT. It turned out that the bush on the pedal was fubar, so the spring wouldn't return the pedal.
14th Oct, 2009 at 09:53:58am
on my conversion instead of using the non servo brake pedal, ive adapted the servo pedal to take the master cylinder rod.
14th Oct, 2009 at 12:06:53pm
i think its defo the servo , gonna change it and rear cylinders and shoes
Edited by EssexSteve on 14th Oct, 2009. |
14th Oct, 2009 at 01:28:45pm
i found today that my pedal was fouling on the down stroke where it goes into the bulkhead, not allowing it to be fully released, havent had time to try it tho.
14th Oct, 2009 at 05:16:54pm
no mate all as i bought it, i drove it home 110 miles no braking issues at all.
