Home > Help Needed / General Tech Chat > metro turbo challenge class 'c' compression ratio
Supercharger
Member #: 7165
Solihull/Birmingham
Hi, does anyone know what the metro turbo challenge cars in class 'c' were allowed to run as their compression ration & head spec. Or does anyone know any good web-sites that detail specifics of these cars. Any help would be appreciated. Simon.
I believe it's 8.5-1, I'm sure our resident racer John Flanigan will be able to confirm.
35.7mm inlet & standard 29.4mm ex.
Edited by Turbo Phil on 13th Oct, 2009.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Maximum permitted is 8.65:1. Just had a look at the regs
http://www.mgmetrocup.co.uk/2009%20Published%20Regs.pdf
On 19th Jan, 2010 wil_h said:
Supercharger
Member #: 7165
Solihull/Birmingham
Sorry, should have said about this when I wrote this down. I bought this engine http://www.turbominis.co.uk/forums/index.php?p=vt&tid=308354 As I am building a supercharged engine. I was basically going to have one of my spare turbo engine built, just like this one, but then it came up for sale. I went to take a look and it is as described, so bought , which saved a fair bit of money over paying for all the work. However the guy selling was really not sure about what the CR was, so I tought if I have to open the chmabers up a bit more it's not the end of the world. I think I will have to then, as this sounds a bit high. It's running the standard exhaust valves alright, but the inlets look bigger. I will take some pics and attach to the post to see what everyone else thinks.
Supercharger
Member #: 7165
Solihull/Birmingham
Here are the pics, any thoughts
AWDmoke
Member #: 713
Western Australia
Get a gauge and just do a compression test instead of pulling the head off.
On 24th Dec, 2008 Nic said:
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
That wont tell you anything though. It will just give you a pressure. To find out the ratio it is easiest to pull the head off
On 30th Apr, 2010 Rod S said:
Gary's description is best
Supercharger
Member #: 7165
Solihull/Birmingham
Cheers Guiys, heads already off, e-mailing benros some pics to see what he thinks.
You won't be able to tell the size of the chambers from a picture though ?
When I did Johns head for his Metro race car the chambers were cut, then the head skimmed to give the correct compression with the 15cc forged pistons they run.
