Home > Wanted > metro parts
EssexSteve
Member #: 7029
Wickford Essex
turbo servo
heater box
and wheres the best place to get brake shoes and wheel cylinders
cheers
steve
Edited by EssexSteve on 13th Oct, 2009.
rear shoes are the same as mini - at least they where on our van
I have a break servo from a MK 1 metro if that's any good.
What do you mean by heater box? The bit that goes in the car with the matrix in it or the bit that goes under the bonnet with the motor in?
EssexSteve
Member #: 7029
Wickford Essex
ap i,m not sure the mk1 is the same .
the heater bit from under the bonnet with the motor
haven't got the fan bit spare at the moment.
Do you mean the servo (round flat bell type bit) or the master cylinder on top of it?
A pic might be easier, then I can see what I've got
EssexSteve
Member #: 7029
Wickford Essex
just the servo, but if it all comes as one thats fine , i think the turbo ones are different though.
Ill try and gat a pic later
steve
I have a spare servo. Needs a good clean but should be fine.
I think the servos are all the same.
Are you going to the rolling road day this weekend??
EssexSteve
Member #: 7029
Wickford Essex
no mate working unfortunatly.
if i can confirm they are how much do you want for it posted to wickford essex ?
steve
£10 plus post? will weigh it when we've made sure it's right
EssexSteve
Member #: 7029
Wickford Essex
ok , cheers
Unless anyone is going sat/sun from essex , i could paypal you the cash and collect form a essex forum member?
steve
EssexSteve
Member #: 7029
Wickford Essex
meant to put it here
looks the same, will get a pic of mine tomorrow. Is there a part number on that sticker/plate on the front edge?
EssexSteve
Member #: 7029
Wickford Essex
I,ll check it tomorow , i called a rover parts palce inn dartford, he reckons they are all the same, but i would still like confirmation..lol
Edited by EssexSteve on 18th Oct, 2009.
Why are you changing it?? mine is in simliar condition, so will need a good clean and paint
EssexSteve
Member #: 7029
Wickford Essex
Because my brakes all came gradually on until they locked while driving , going to change the servo rear wheel cylinders and rear shoes.
